souvik Posted February 3, 2014 Share Posted February 3, 2014 Hi I am attaching a cross section of a canal designed in Autocad. Now my professor need this cross section in excel. Is there any way or lisp or any thing by which I can convert this to excel.. Quote Link to comment Share on other sites More sharing options...
MSasu Posted February 3, 2014 Share Posted February 3, 2014 Please look to DATAEXTRACTION built-in command; select the labels and extract their Value property. This will work well if the creation order of those values coincides with their location; other will need to do some reordering in Excel. Quote Link to comment Share on other sites More sharing options...
souvik Posted February 4, 2014 Author Share Posted February 4, 2014 Sorry sir for late reply. I have tried dataextraction but it is not helping me. I have near about 100 cross section. please make some more guidance on excel recording... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 5, 2014 Share Posted February 5, 2014 This is not a easy task its very doable you have different ways to achieve the end result, the simplest way is to not connect direct to excel but rather write a csv file. A suggestion would be to modify this program it reads columns of text and exports them out you would have to change to be horizontal not vertical. Automating to do a 100 crosssections big task to keep them in correct order. We use ARD and it has a cross section listing option so a bit of work in word and all done. I can not rememeber if there is the same in civ3d need to look under the REPORTS option in the ribbon it has a number of export routines. Toolspace Toolbox reports ; converts column of text to comma seprated file with text value and y value ; put in excell and sort by y value ; by Alan H Nov 2004 (setq x 1) (while (/= x 4) (setq howmany (rtos x 2 0)) (setq fileto (strcat "c:/temp/setout" howmany)) (princ fileto) (setq fout (open fileto "w")) (while (not (setq ss (ssget )))) (princ "wow") (while (setq en (ssname ss 0)) ; Entity type (setq entyp (cdr (assoc 0 (entget en)))) (princ "wow") (if (= entyp "TEXT") (progn (setq xyz (cdr (assoc 10 (entget en)))) (setq txtht (cdr (assoc 1 (entget en)))) ;write file out here (setq textout (strcat txtht "," (rtos (cadr xyz) 2 3))) ;write (write-line textout fout) (princ textout) ) ) ; Delete each measured entity from set (ssdel en ss) ;end while ) (close fout) (setq x (+ x 1)) ) ;end if loop 3 times (princ) Quote Link to comment Share on other sites More sharing options...
