Hi,
I have a drawing with a detail, I want to hide dimension from the big view port and show it in the detail as you can see in the picture:
I use Annotative dimension.
Thank you ;)
As long as the dimension is on its own layer it would be no problem to do just freeze the dim layer in the circular viewport.
Thank you ReMark :)
It's OK I have put dimension on Paper space, It's a small drawing.
You might also want to check 'annotation scale'. You can manage which annotation should appear in particular scale.
  • 2 weeks later...
dimensions are always in paper space here else his old school
One might think that is the case however AutoDesk, in its infinite wisdom, gave users the option to keep text and dimensions in model space when they added the annotative scaling feature. And for some disciplines that feature does offer some advantages. I for one, however, do not use annotative scaling but I am not about to force my view down anyone's throat. My advice is to try it both ways then make a choice. At least it will be an informed decision.
