Rooster Posted December 1, 2008 Posted December 1, 2008 I'm wanting to edit a load of blocks and untick the option that says 'Allow Exploding" so that I can use that in a template for my Explode-Happy-Colleagues who irritatingly explode my blocks At the moment, the only way I can see of doing this is exploding & then redefining each block, but doing this means that I have to go through and recreate the dynamic elements as well, etc. I was wondering whether there is a better/quicker way (eg. in Block Editor - although I have looked and can't see one) of just making the block unexplodable?? Quote
dbroada Posted December 1, 2008 Posted December 1, 2008 you should be able to BMAKE and select the existing block, either by name or by clicking. off to try...... BMAKE and select your block from the drop down list. Click OK, accept redefinition. No exploding. Quote
lpseifert Posted December 1, 2008 Posted December 1, 2008 Start the Block commad, select the block name from the drop-down list, uncheck 'Allow exploding'', save. Quote
Rooster Posted December 1, 2008 Author Posted December 1, 2008 Thanks folks - I knew there must be a simple way somewhere!! Quote
