ReMark Posted January 27, 2014 Posted January 27, 2014 What did you do that the Program Compatibility Assistant fired up? Are you utilizing AutoCAD 360 by any chance? Quote
CADMASTER1128 Posted January 27, 2014 Author Posted January 27, 2014 Your guess is as good mine ReMark Quote
ReMark Posted January 27, 2014 Posted January 27, 2014 AutoCAD 360 is a cloud based platform that gives the user access to storage and other cloud-based services. Quote
CADMASTER1128 Posted January 27, 2014 Author Posted January 27, 2014 No, I am not logged into ACAD 360... I used too but that caused errors. Quote
ReMark Posted January 27, 2014 Posted January 27, 2014 So far the only info I've found re: acsettingsync.exe (the process that is causing the error) references AutoCAD 360. Have you tried totally disconnecting yourself from your network? Quote
CADMASTER1128 Posted January 27, 2014 Author Posted January 27, 2014 No I have not... I did restart the System and sees to be working good right now. Quote
ReMark Posted January 27, 2014 Posted January 27, 2014 I'm wondering if some of your problems would disappear if you were totally disconnected from the network. Is it possible to test? Quote
CADMASTER1128 Posted January 27, 2014 Author Posted January 27, 2014 I'll get with IT to see if that is OK. IF it is I will post the results. Quote
