BarbM Posted January 21, 2014 Posted January 21, 2014 Assemblies are built with cross hatching, or shading, built in - can I style (edit) the cross hatch? I'd like to be able to hide/show the hatching, or at the very least change the color to what will print as a half tone. Any tips? I've looked everywhere, but had no luck. Quote
Bill_Myron Posted January 21, 2014 Posted January 21, 2014 Those are part of the Shape Style. You can change layer, color, pattern, On\Off. To find what shape your assembly uses, go to the assembly properties, under Codes it will list the shapes it uses. Quote
BarbM Posted January 21, 2014 Author Posted January 21, 2014 Thank you Bill. I'll look into it and let you know how it goes. Quote
BarbM Posted January 21, 2014 Author Posted January 21, 2014 Got it Bill - thanks! I just didn't dig down deep enough, or make the connection between codes and shapes. Thanks again. Quote
