Luís Augusto Posted January 20, 2014 Posted January 20, 2014 Hello everybody. In research here in the forum, I found a lisp program written by Lee Mac that makes the insertion of all the blocks in the drawing asking an insertion point. I found it very useful. It would be possible to adapt to insert blocks reading from a csv file and bring the values of attributes? The blocks are not loaded in the drawing, so the directory is previously loaded in Suppot File Search Path. This is the program mentioned above. (DEFUN C:BLKINS (/ pt name) (vl-load-com) (setq *acad* (vla-get-ActiveDocument (vlax-get-acad-object))) (setq *ms* (vla-get-ModelSpace *acad*)) (vlax-for item (vla-get-Blocks *acad*) (if (and (not (eq "*" (substr (setq name (vla-get-Name item)) 1 1))) (setq pt (getpoint "\nSelect Point for Block: "))) (vlax-invoke-method *ms* 'InsertBlock (vlax-3d-point pt) name 1.0 1.0 1.0 0.0))) (princ)) Thank you in advance. Regards, Luís Augusto. Quote
BIGAL Posted January 21, 2014 Posted January 21, 2014 if you have a csv file then just open in excel and make a script you use the concatenate commnad in excel to join columns. you need the line to be something like this Insert block1 x,y 1 0 asdf ghjk.... two attributes Quote
Luís Augusto Posted January 21, 2014 Author Posted January 21, 2014 if you have a csv file then just open in excel and make a script you use the concatenate commnad in excel to join columns. you need the line to be something like this Insert block1 x,y 1 0 asdf ghjk.... two attributes Sorry Bigal . I think you misunderstood me . I intend to find a routine that ask me the location of the table containing the values of the blocks and their attributes , and then do the insertion of blocks asking me where the position will be inserted and not having to provide a coordinate x , y , z . I found something like the following topic , but was unable to reuse code . http://www.cadtutor.net/forum/showthread.php?53100-Inserting-blocks-and-attributes-with-LISP I Requested the code for the holder but got no success, so I'm requesting help. I Work with the design of electrical harnesses for agriculas machines and inserting attributes in connectors with loads of pinouts is quite laborious . Today I use the excellent program Batch Attribute Editor Master Lee Mac , but still have to insert all connectors before making the importation of attributes . I would like to fully automate this task . Does anyone know where to find something? Thanks for help. Quote
Tharwat Posted January 21, 2014 Posted January 21, 2014 As long as you have the drawing that contains the blocks in the Support folder , it would be easy to find and insert the drawing into the current one . Upload a sample sheet of Excel fie with extension .csv How would you insert the each block and how should the codes know that you are going with that block or another ? Quote
Bhull1985 Posted January 21, 2014 Posted January 21, 2014 So from reading these posts I would guess that the OP wants to have tables in excel, electrical harnesses on one page, for instance. So he tells the program which sheet number in excel document, and then the program grabs all of the cells and inserts based on the first column being the name of the block. It would allow sequential insertion of the blocks with a click for each insertion point, where the program then places the block. That's how I read it, HTH Quote
Luís Augusto Posted January 21, 2014 Author Posted January 21, 2014 Tharwat, thank you for your interest in helping. Following examples as requested. Thank you in advance. Sample Conectors.zip Quote
Tharwat Posted January 21, 2014 Posted January 21, 2014 Tharwat, thank you for your interest in helping. Following examples as requested. Thank you in advance. I wish I could Now , how would you insert these blocks to drawings ? I mean the insertion point ? Pick on the screen with pause option ? Quote
Luís Augusto Posted January 21, 2014 Author Posted January 21, 2014 I wish I could Now , how would you insert these blocks to drawings ? I mean the insertion point ? Pick on the screen with pause option ? The idea is the following. The program would let me know the name of the connector to be inserted and I choose the position manually. Quote
Tharwat Posted January 21, 2014 Posted January 21, 2014 The tow blocks named Right headlight and Left headlight are having the last attributes with a strange one (value) to me , if you insert any value it keep on asking you for more inputs although in the Excel file there are only four values for the fore-said blocks . So should the last attribute be with nil value to avoid the other asks for more values or what ? Quote
Luís Augusto Posted January 21, 2014 Author Posted January 21, 2014 The tow blocks named Right headlight and Left headlight are having the last attributes with a strange one (value) to me , if you insert any value it keep on asking you for more inputs although in the Excel file there are only four values for the fore-said blocks . So should the last attribute be with nil value to avoid the other asks for more values or what ? Tharwat, sorry for the failure. TAG PN_ORIGINAL giving this problem. She is not more inside the block. You can ignore them. The information should be entered only in tags that start with PIN_. Man, I have no words to thank for their help and other colleagues here in the forum. Thank you very much. Quote
Luís Augusto Posted January 21, 2014 Author Posted January 21, 2014 So from reading these posts I would guess that the OP wants to have tables in excel, electrical harnesses on one page, for instance.So he tells the program which sheet number in excel document, and then the program grabs all of the cells and inserts based on the first column being the name of the block. It would allow sequential insertion of the blocks with a click for each insertion point, where the program then places the block. That's how I read it, HTH Dear bhull1985, forgive me for not seeing your comment. Essentially this is the idea. Many thanks for your interest in the subject and I'm sorry not to have answered before. If you have any suggestion or idea to add, feel free. Regards, Luis Augusto. Quote
Tharwat Posted January 22, 2014 Posted January 22, 2014 (edited) Tharwat, sorry for the failure. TAG PN_ORIGINAL giving this problem. She is not more inside the block. You can ignore them. The information should be entered only in tags that start with PIN_. Man, I have no words to thank for their help and other colleagues here in the forum. Thank you very much. It's okay I have just finished the routine and hope it would work as best as you looking for . Try it and let me know . (defun c:Test (/ *error* Deconstruct_String right left con1 con2 xl ok o st l lst a b c d f fp bn p go vl name ch) ;; ;; ;; Author : Tharwat Al Shoufi ;; ;; ;; (or doc (setq doc (vla-get-activedocument (vlax-get-acad-object)))) (defun *error* (u) (if ch (setvar 'CMDECHO ch) ) (princ "\n*Cancel*") ) (defun Deconstruct_String (st delimiter / p l) (while (setq p (vl-string-search delimiter st 0)) (setq l (cons (substr st 1 p) l) st (substr st (+ p 2) (strlen st)) ) ) (if st (setq l (cons st l)) ) (setq l (reverse l)) ) (if (setq xl (getfiled "Select the required Excel file :" (getvar 'DWGPREFIX) "csv" 16)) (progn (setq ok t ch (getvar 'CMDECHO) o (open xl "r") ) (setvar 'CMDECHO 0) (while (setq st (read-line o)) (setq l (cons (setq st (Deconstruct_String st ",")) l) lst (cons (strcase (car st)) lst) ) ) (close o) ) (setq ok nil) ) (if (and ok (/= (setq bn (getstring t "\n Specify Attributed Block name to insert :")) "") (if (member (setq bn (strcase bn)) lst) t (progn (alert "Block name is not included in the Excel file <!>") nil) ) (if (not (tblsearch "BLOCK" bn)) (if (setq fp (findfile (strcat bn ".dwg"))) (progn (command "_.-insert" fp nil) t) (progn (alert "Block Name is not found in Support Folder <!>") nil) ) t ) ) (progn (setvar 'CMDECHO ch) (vla-StartUndoMark doc) (while (setq p (getpoint "\n Specify insertion point :")) (setq vl (vla-insertblock (vla-get-block (vla-get-activelayout doc)) (vlax-3d-point p) bn 1.0 1.0 1.0 0.)) (foreach x (vlax-invoke vl 'getattributes) (foreach tg l (if (and (eq (car tg) (strcase bn)) (eq (strcase (vla-get-tagstring x)) (cadr tg))) (vla-put-textstring x (caddr tg)) ) ) ) ) (vla-EndUndoMark doc) ) ) (princ) ) (vl-load-com) Edited January 23, 2014 by Tharwat Codes Updated as per OP's needs Quote
Luís Augusto Posted January 22, 2014 Author Posted January 22, 2014 It's okay I have just finished the routine and hope it would work as best as you looking for . Try it and let me know . Tharwat, sorry for the delay in responding. Did a great job my friend. The program was very good, this is really the idea but, in my view two things would be interesting. The first one would be to point the file location. Csv by explorer. The second and more important in my opinion, would not limit the routine to certain connectors (names). I believe the list to insert the blocks should be based on reading the first line of the file. Csv as quoted by BHULL1985. this way the program will become dynamic. Thank you for your valuable contribution. I believe this program can be used by many people. Regards, Luís Augusto. Quote
Tharwat Posted January 23, 2014 Posted January 23, 2014 Hi Luis . Sorry for this late reply , a few urgent work prevented me to get back to you on time . To allow the user to select the Excel file , that is easily could be done , but what about the blocks ? How much is the quantity of blocks that you are planning to insert in each drawing and then to feed them with attribute values / strings ? Quote
Luís Augusto Posted January 23, 2014 Author Posted January 23, 2014 Hi Luis . Sorry for this late reply , a few urgent work prevented me to get back to you on time . To allow the user to select the Excel file , that is easily could be done , but what about the blocks ? How much is the quantity of blocks that you are planning to insert in each drawing and then to feed them with attribute values / strings ? Do not worry Tharwat. The path of the blocks will be informed before. I'll use the Support file search path, this way need not be handled by the program. The amount of blocks, well, that can vary from 2 to 30, depending on the size of the project. I imagined the following. The program will read the first column and generate a list of distinguished names for insertion. For each list item, then bring the values. This part of the program is already running fine. Quote
Tharwat Posted January 23, 2014 Posted January 23, 2014 The path of the blocks will be informed before. I'll use the Support file search path, this way need not be handled by the program. Does that mean that you have all needed blocks in the support folder ? and are listed in the Excel sheet as the one you uploaded before here ? Quote
Tharwat Posted January 23, 2014 Posted January 23, 2014 CODES UPDATED in post No# 12 Try it and let me know . Quote
Luís Augusto Posted January 23, 2014 Author Posted January 23, 2014 (edited) Tharwat, the program is getting excellent! Can I ask you one last change? Could the program let me know the name of the conectors instead of a manual entry? Edited January 23, 2014 by Luís Augusto Quote
Luís Augusto Posted January 23, 2014 Author Posted January 23, 2014 (edited) What do you mean by that ? Have I fixed your name. Tharwat, I wrote wrong, sorry. Here is a suggestion. Prompt: Specify insertion point: Then specific ... Next Prompt: Specify insertion point: Then specific ... Next Until it runs out the possibilities ... Edited January 23, 2014 by Luís Augusto Quote
