Butch Posted November 30, 2008 Posted November 30, 2008 Hello:-) Any chance of making this work? Im using old 2004 version. Thanx in advance :-) Quote
Strix Posted December 1, 2008 Posted December 1, 2008 you want your shift key to be your ortho on/off? is this something you've seen done elsewhere? Quote
bonehead411 Posted December 1, 2008 Posted December 1, 2008 Make the shift key toggle ortho on/off? But that's madness! Why would you want to do that? The shift key has too much functionality to go changing it. I beg you Sir, please reconsider. Quote
dbroada Posted December 1, 2008 Posted December 1, 2008 especially as it is already on a toggle key Quote
Tiger Posted December 1, 2008 Posted December 1, 2008 and Ortho On/Off is already set to the F8-key - isn't that enough? dang...lost to Dave :wink: Quote
dbroada Posted December 1, 2008 Posted December 1, 2008 but at least the same time stamp :wink: Quote
Butch Posted December 1, 2008 Author Posted December 1, 2008 OK guys, I hear you, but can it be done? Quote
dbroada Posted December 1, 2008 Posted December 1, 2008 I'm not sure that it could and you would break a lot of commands if you were to do so. Why do you want this? Quote
Butch Posted December 1, 2008 Author Posted December 1, 2008 Its just that Im used to model in Rhino, holding SHIFT will turn ortho mode and when releasing, it would disable it. Quote
dbroada Posted December 1, 2008 Posted December 1, 2008 the shift key is used for too many other things for it to be viable. Either F8 or ctrl-L are available while in the middle of a command. Quote
dbroada Posted December 1, 2008 Posted December 1, 2008 I don't know about others but I was reluctant to investigate as this sounded like a "joke" post (we get them from time to time). Putting this function on the shift key would stop so many other things from working that I wouldn't be happy if it were done to me. Having now seen your reason I still think its not possible. Quote
Tiger Posted December 1, 2008 Posted December 1, 2008 I'm with Dbroada on this, don't know if it can be done and really don't want to fiddle my cad to find it out, like he said, the Shift key is used for so many other things. However, if you type in CUI you'll get to the Custom User Interface where you can change a lot of settings and keybindings and such. You might also be intrested in changing the PGP-file where you save all your short commands (like typing M to get the MOVE command), you'll find it under Express > Tools > Command Alias Editor. And if you do make it work, please come back and tell us, we're always interested in new customisations Quote
hazardman Posted December 1, 2008 Posted December 1, 2008 ...However, if you type in CUI ... he's using 2004...is that command available or was that introduced in 2006?.. Quote
Tiger Posted December 1, 2008 Posted December 1, 2008 he's using 2004...is that command available or was that introduced in 2006?.. That's true, it was introduced in 2006....perhaps it will work with Tools > Customize > Interface instead. Quote
rkent Posted December 1, 2008 Posted December 1, 2008 Make the shift key toggle ortho on/off? But that's madness! Why would you want to do that? The shift key has too much functionality to go changing it. I beg you Sir, please reconsider. It isn't madness, that is how Shift works and has for several releases. Start line command, pick a point, hold Shift down, Ortho is toggled off or on, release it and the toggle goes back. It has been so long since '04 I don't remember if that was there already, if not there probably isn't a way, not an easy one any way. Quote
Tiger Posted December 1, 2008 Posted December 1, 2008 It isn't madness, that is how Shift works and has for several releases. Start line command, pick a point, hold Shift down, Ortho is toggled off or on, release it and the toggle goes back. It has been so long since '04 I don't remember if that was there already, if not there probably isn't a way, not an easy one any way. i think we all assumed that it was a permanent toggle the OP was asking for, now it doesn't seem like it is, which makes more sense. Don't know what/where to control the temp-toggles so to speak, but it would be good to know - so anyone know where their settings is stored? Quote
dbroada Posted December 1, 2008 Posted December 1, 2008 I certainly assumed a permanent toggle. I wasn't aware of the shift giving instant ortho so again, something new learned today. We have to assume it wasn't the case with 2004 else the question would not have been asked. Quote
Tiger Posted December 1, 2008 Posted December 1, 2008 ok so it's actually how it works in post-2006 versions! Like Dave, I've learnt something new today Quote
soleary Posted December 1, 2008 Posted December 1, 2008 Don't know what/where to control the temp-toggles so to speak, but it would be good to know - so anyone know where their settings is stored? This is controlled by the 'tempoverrides' system variable. With it set to 1 the shift key can be used like described above or with other keys for other commands. Funnily enough, I actually never use them Quote
Strix Posted December 1, 2008 Posted December 1, 2008 so who's going to post it in the tips thread? Quote
