davidneedsassistance Posted January 17, 2014 Posted January 17, 2014 I'm in AutoCAD Architecture 2010. I've lost all menubars and need to reload. I was perfectly happy with the 2010 ribbon. When I search other forums it seems the answers are all geared toward restoring the older format of menubars because people are unhappy with the 2010 ribbon. That does not apply to me. I just want to restore the default 2010 ribbon menubar. I've tried the "Menubar" command and have not found the original 2010 default menubar. Maybe it's there and I'm not figuring it out. Can someone steer me to a path to reset and re-establish the default 2010 setup? I prefer to not have to uninstall and re-install the program to get back to the default settings if I don't have to. Thanks Quote
ReMark Posted January 17, 2014 Posted January 17, 2014 Have you tried switching workspaces? Have you tried resetting your Profile? Please do NOT uninstall your program unless it is absolutely necessary. Quote
davidneedsassistance Posted January 17, 2014 Author Posted January 17, 2014 Hi ReMark. Thanks for responding. I have generated a fatal flaw in the interim. Bummer. CAD won't even remain open. Do you think uninstalling and reloading is necessary at this point? Quote
ReMark Posted January 17, 2014 Posted January 17, 2014 No, I do not. What were you doing when the fatal error occurred? Quote
davidneedsassistance Posted January 17, 2014 Author Posted January 17, 2014 I was attempting to reload a menubar per another blogger's instructions to someone else. This is embarrassing. I'm fairly competent at drawing. Much less competent at adjusting settings, etc. I'm not smart enough to be able to tell you the extent to which I have messed things up. Quote
ReMark Posted January 17, 2014 Posted January 17, 2014 If you are following some other instructions then by all means go right ahead. I'll go back to my drawing. Good luck. Quote
davidneedsassistance Posted January 17, 2014 Author Posted January 17, 2014 ReMark, you misunderstand. This is something I did prior to your first communication with me. Quote
ReMark Posted January 17, 2014 Posted January 17, 2014 My aim was to not overload you with information. You try one thing at a time and if it doesn't work you go to the next. At the moment I'm trying to assist someone else. Be patient....I'll be back. Quote
ReMark Posted January 17, 2014 Posted January 17, 2014 OK...I'm back. Please refer to my questions in post #2. Quote
davidneedsassistance Posted January 17, 2014 Author Posted January 17, 2014 What I was trying to do when the fatal error occured was to restore my 2010 default ribbon menu bar Quote
ReMark Posted January 18, 2014 Posted January 18, 2014 Yes, I understand that. And what I am still trying to do is get answers to the questions I asked in post #2. Your cooperation would be appreciated. Thank you. Quote
ReMark Posted January 18, 2014 Posted January 18, 2014 In response to a similar post forum member nestly posted the following: - - - - - - - - - - - - - - - - - - - - The ribbon and the workspaces are stored in the CUIx files, so my guess is that somehow either the CUI's got moved to a different location on the hard drive, or the path to the CUIx files changed. If the CUIs appear in the CUI (CUI command) you can try to "restore" them, which will load the previously saved version. Restore/Reset Acad cui file First though, you should verify that the CUIs are still where they're supposed to be, and that location is correct in Tools > Options > Files > Customization Files > Main Customization File. By default, the cui's should be at C:\Users\username\appdata\roaming\autodesk\autocad 2013 - english\r19.0\enu\support (for Windows7) As a last resort, Start > Programs > Autodesk > AutoCAD2013 > Reset settings to default. This should restore the ribbon and workspaces, but customizations will have to be restored manually. - - - - - - - - - - - - - - - - - - - - So there you have it. You can try my two suggestions first, if you haven't already done so, and should they fail to fix the problem then try nestly's suggestion. If the problem persists then my next recommendation would be to do a REPAIR of your installation. A REPAIR is NOT the same as an Uninstall/Reinstall. That option should always be the one of last resort. You got all that? Good luck. Let us know what happens. Quote
davidneedsassistance Posted January 19, 2014 Author Posted January 19, 2014 Thank you so much for your concern, your recommendations, and your time. I appreciate it. In the end I was on the telephone with an IT person (and old friend) who had control of my computer from remote access. He spent over two hours doing a number of procedures that were very complex. He was absolutely flying all over the place. AutoCAD is now restored and functioning. Thanks again, David Quote
ReMark Posted January 19, 2014 Posted January 19, 2014 Glad to hear you are back up and running. Do you know what he did that ultimately fixed the problem? Thank you for updating us. Quote
davidneedsassistance Posted January 20, 2014 Author Posted January 20, 2014 I wish I could tell you but after 2 plus hours it was all a swirl. Very complex. It also involved trying some things and then changing direction several times. You folks in your line of work have great talent and it sure seems like job security as well. You are very necessary , essential in fact. Just as attorneys can be at times. But I like you all more than I like attorneys (in general of course) Quote
ReMark Posted January 20, 2014 Posted January 20, 2014 Well that's too bad. I was hoping you could share some information with us that might help other users with a similar problem in the future. But it is what it is. Thanks for the update. Quote
