Tharwat Posted January 18, 2014 Posted January 18, 2014 Whatever the result,all want to thank you! I will try. Okay , Try it and let me know . Quote
lucas3 Posted January 18, 2014 Author Posted January 18, 2014 Okay , Try it and let me know . I just tried,The lack of sub-style, in post#1 ,Step 2.3 and 2.4 Quote
lucas3 Posted January 18, 2014 Author Posted January 18, 2014 What is the need of that overrides ? Thank you ,Tharwat ,Maybe you are right! If need overrides , how to do?Difficult? Quote
Tharwat Posted January 18, 2014 Posted January 18, 2014 I don't know how to make that overrides with lisp although I think it is a matter of error or irregular process that may take a place in any drawing with any dimension style. Quote
lucas3 Posted January 18, 2014 Author Posted January 18, 2014 (edited) I don't know how to make that overrides with lisp although I think it is a matter of error or irregular process that may take a place in any drawing with any dimension style. (defun mksubdimsty (name mod lst / dims nname) (setq dims (vla-get-dimstyles (vla-get-activedocument (vlax-get-acad-object)) ) ) (if (and (tblsearch "dimstyle" name) (setq nname (strcat name mod)) (not (tblsearch "dimstyle" nname)) ) (progn (vla-put-activedimstyle (vla-get-activedocument (vlax-get-acad-object)) (vla-item dims name) ) (vl-cmdf ".dimstyle" "s" nname) (if lst (progn (mapcar '(lambda (x) (apply 'setvar x)) lst) (vl-cmdf ".dimstyle" "s" nname "y") ) ) ) ) (princ) ) (mksubdimsty "custom" "$3" '(("DIMTOH" 1) ("DIMTIH" 0)) ) This function? Edited January 19, 2014 by lucas3 Quote
lucas3 Posted January 18, 2014 Author Posted January 18, 2014 (edited) (vl-load-com) (defun mksubdimsty (name mod lst / dims nname) (setq dims (vla-get-dimstyles (vla-get-activedocument (vlax-get-acad-object)) ) ) (if (and (tblsearch "dimstyle" name) (setq nname (strcat name mod)) (not (tblsearch "dimstyle" nname)) ) (progn (vla-put-activedimstyle (vla-get-activedocument (vlax-get-acad-object)) (vla-item dims name) ) (vl-cmdf ".dimstyle" "s" nname) (if lst (progn (mapcar '(lambda (x) (apply 'setvar x)) lst) (vl-cmdf ".dimstyle" "s" nname "y") ) ) ) ) (princ) ) (defun Text+Dim nil ;; Tharwat 17. Jan. 2014 ;; (if (not (tblsearch "STYLE" "ggg")) (entmakex '((0 . "STYLE") (100 . "AcDbSymbolTableRecord") (100 . "AcDbTextStyleTableRecord") (2 . "ggg") (40 . 0.) (41 . 1.) (42 . 1.0) (50 . 0.) (70 . 0) (71 . 0) (3 . "gdt.shx") (4 . "gbcbig.shx") ) ) ) ;; ;; (if (and (not (tblsearch "DIMSTYLE" "custom")) (tblsearch "STYLE" "ggg") ) (entmakex (list '(0 . "DIMSTYLE") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbDimStyleTableRecord") '(2 . "custom") '(70 . 0) '(41 . 2.5) '(42 . 2.0) '(43 . 7.0) '(44 . 2.25) '(73 . 0) '(77 . 1) '(78 . '(140 . 2.5) '(141 . 2.5) '(171 . 3) '(172 . 1) '(271 . 2) '(272 . 2) '(274 . 3) '(278 . 44) '(283 . 0) '(284 . (cons 340 (tblobjname "STYLE" "ggg")) ) ) ) (mksubdimsty "custom" "$3" '(("DIMTOH" 1) ("DIMTIH" 0)) ) (princ) ) Edited January 19, 2014 by lucas3 Quote
