This is a dimension for countersunk hole, if use autolisp how to do this?
if use dimdiameter to do this,How to add text under the horizontal line?
I know,the dim font is gdt.shx, Lowercase letters “v" is countersunk hole symbol,Lowercase letters “x" is the depth of the symbol
When editing the dimension use "\X" (capital letter) to get a new line of label.
  • 2 months later...
help!,help!,help!
I according to do that, but …… why? :cry:
100.dwg
I use A2007 is this kind of situation, but A2010 is correct, why? Version of the problem?
Is there a solution?
I am not sure why it did not work for you. But I looked at your drawing. Replace the X with a P and press enter. Then replace the P with the X again and press enter. this produces the desired result. I am not sure why it is not displaying correctly the first time.
are u saying that it is still not working for you?
I use a2007 ,use "\X" but rather places both lines of text above. What is going on?
Look,some times,all text above the line,
