Daniel_K Posted November 30, 2008 Posted November 30, 2008 Hi, I have a problem with interpreting my object in AutoCAD 2008... What is wrong with them? Quote
ReMark Posted November 30, 2008 Posted November 30, 2008 The door jam on the right might actually extend into the wall. That's my best guess. The other one, to the left, I'm not sure what's happening. Quote
shift1313 Posted November 30, 2008 Posted November 30, 2008 a lot of times you will get an image like this if you actually have two surfaces(or solids) that are identical. Is it possible there is a copy behind them? you can delete one and see if there is still something there. you can always use UNDO. Quote
Daniel_K Posted November 30, 2008 Author Posted November 30, 2008 It is a big problem becouse I'm modeling some building on AutoCAD 2008 and AutoCAD 2009 and I have a the same problem. I don't know why? When I start modeling everything is great, then... I don't know when... my object look like in the image. shift1313: it's not copy... Quote
Daniel_K Posted November 30, 2008 Author Posted November 30, 2008 I deleted another wall end left only one. Problem is still there. It's a realistic visual style and you can see lines that should be invisible... Quote
shift1313 Posted November 30, 2008 Posted November 30, 2008 what are your computer specs. video ram and graphics card? What happens if you rotate the part around, are those spaces always in the same place or do they move a bit? what about changing the shademode Quote
Daniel_K Posted November 30, 2008 Author Posted November 30, 2008 HDD 250 GB VRAM 512 MB CPU Intel Core 2 Duo 2.5 GHz Memory 4 GB If I rotate the part around, the spaces is always in the same place. Where I can changing the shademode? Quote
shift1313 Posted November 30, 2008 Posted November 30, 2008 you can either type in SHADEMODE and follow the options, or you can use the tool bar. It should be under the visual styles menu at the top. You will have several options including realistic or conceptual, i cant remember how its worded. Switch to one of those and tell us if it appears the same. Im not sure what shademode you are in because it appears to be a combination between 3d wireframe and flat shaded. In acad 08 there is a visual styles manager as well where you can change options but i do not have this version so i cant really help you with that. What graphics card is in your computer? I have trouble with ATI video cards or a regular basis with several different cad packages. I have had good luck with NVIDIA cards. Quote
mugshot Posted December 1, 2008 Posted December 1, 2008 try zooming in the part where the unusual thing is and regenerate... sometimes overlapping two solid has crapy visual.... what is the sacle you are using anyway? Quote
nocturne00 Posted December 1, 2008 Posted December 1, 2008 Try to check out this link- and the links on them, its not too far from your problem http://www.cadtutor.net/forum/showthread.php?t=26725 Quote
