jjar Posted January 13, 2014 Posted January 13, 2014 Are there some easy ways to sort of simulate making an assembly in inventor lt (we do not have the assembly option) ? What is the simplest way to combine parts? So far we have been using the Derive command but it has been difficult to move the added part to the desired location. Quote
JD Mather Posted January 13, 2014 Posted January 13, 2014 You can make multi-body solids in LT. I have not used LT so I don't know if you can also move solid bodies in LT. Is there a Move Bodies tool n the Modify ribbon? Quote
