Circle Leader with Detail Inside?
Is it possible for me to insert a circle leader into my drawing, with a small detail drawing inside?
I have a few areas on some technical drawings I'm doing that need to show detail, and I'm trying to keep the drawing to one sheet.
The only detail leader I seem to be able to insert is the one with a horizontal line and two reference numbers (view & sheet).
If this isn't possible, what are some ways I can insert details into my dwg without making everything look cluttered?
Thanks!
Yes, starting in AutoCAD 2013, there is a feature named Detail Views.
There is a Youtube video here that explains it all.
Here is a screenshot also, to make sure we are talking about the same thing.
Yes, that's what I'm talking about. thank you very much for all the help!
Oh... I would not have expected the Detail Views tool to work in AutoCAD LT. :o
I haven't tried yet. I will let you know if it does work.
You won't find that in LT. If you use layouts then you can easily do that by making a viewport in a circular shape.
Ouch. That is a bummer for the OP.
Yea, looks like doing it the old fashioned way....
Oh man. That really is a bummer. But I may have some drawings I could import as DXFs from V-Carve Pro that I can use as close-ups for my blocks. Thanks folks!
Thanks!
Just create a viewport within your layout area and then point a leader to the area you want. You can switch between viewports by ctrl+r
you can make the viewport any shape circle, rectangle waht ever.
cheers D
autocad tutorial give for you how to learn autocad
NTD, please start a new thread if you have a new questoin - don't tack your question onto an exisiting thread.
So, I got that figured out.
Thanks a lot guys, I really appreciate it.
