Skyuro Posted January 12, 2014 Share Posted January 12, 2014 hello, i have a problem. First i did a model in CATIA after that i import it to AUtocad. Everything was ok with model but in zoom in model are discontinuities. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 13, 2014 Share Posted January 13, 2014 Maybe if you attach a copy of the drawing to your next post we can get a better idea about the problem(s) you are facing. When you brought the model into AutoCAD what form did it take? Is it a mesh, a surface or a solid? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted January 13, 2014 Share Posted January 13, 2014 Try increasing viewres and facetres then regen. Quote Link to comment Share on other sites More sharing options...
Skyuro Posted January 14, 2014 Author Share Posted January 14, 2014 it was saving to .stp, it is solid. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 14, 2014 Share Posted January 14, 2014 Ok, so you imported a STEP file and you say you ended up with a solid. I still don't have a clear picture of where these inconsistencies are being encountered. A DWG file would be helpful. If not that how about an image (a closeup)? Quote Link to comment Share on other sites More sharing options...
