Bogbadbob658 Posted January 7, 2014 Share Posted January 7, 2014 I'm having trouble using the blockreplace' command. Every time I try it tells me the block name has invalid characters. The attached files is an example of the issue. I'm trying to replace the old block with the new block. FILE_1.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 7, 2014 Share Posted January 7, 2014 Could the problem be the fact that if one were to select the block the object name contains an invalid character or that the block also has anonymous name of *U19? Command: blockreplace Select an object with the desired block name... Select objects: *U19 Invalid characters in block name. The following characters are invalid: \/": ? *|,=` Select objects: Command: LI LIST Select objects: 1 found Select objects: BLOCK REFERENCE Layer: "0" Space: Model space Handle = 1cef3 Block Name: "H534_old" Anonymous Name: "*U19" at point, X= 624.890 Y= 300.394 Z= 0.000 X scale factor: 1.000 Y scale factor: 1.000 rotation angle: 0.00 Z scale factor: 1.000 InsUnits: Meters Unit conversion: 1.000 Scale uniformly: No Allow exploding: Yes Lookup: As Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 7, 2014 Share Posted January 7, 2014 I did get the BLOCKREPLACE command to work. Insert a copy of H534_old. Erase the previous version of the block. Run the PURGE command and use the Block option. Purge block *U19. Now run the BLOCKREPLACE command. Quote Link to comment Share on other sites More sharing options...
Bogbadbob658 Posted January 7, 2014 Author Share Posted January 7, 2014 I assume the anonymous name is assigned because it's a dynamic block? So is there anyway of replacing dynamic blocks with the same block name but not the same anonymous name with another dynamic block? I'm trying to do this to a file that has multiple copies of the block. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 7, 2014 Share Posted January 7, 2014 I don't know how it got the anonymous name. How was the block introduced into the drawing in the first place? I believe the answer to your problem appears in post 6 of 8 (by lpseifert) of this thread... http://forums.autodesk.com/t5/AutoCAD-2007-2008-2009-DWG/Dynamic-blocks-and-anonymous-names/td-p/2217786 Quote Link to comment Share on other sites More sharing options...
Bogbadbob658 Posted January 7, 2014 Author Share Posted January 7, 2014 The blocks where copied and pasted into the drawing. It seems to get the anonymous name once you have selected one of the dynamic options. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 7, 2014 Share Posted January 7, 2014 Did you access the link I provided in post #5? I have read that anonymous blocks can be attributed to hatch patterns, dimensions, Autolisp and changing the visibility state of a dynamic block to name a few possibilities. Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 7, 2014 Share Posted January 7, 2014 Put the new block into a separate drawing, with the 'old' drawing as active, open the design center dialogue and find the new block, right click and select "redefine only". That should work? providing the real names are the same Quote Link to comment Share on other sites More sharing options...
Bogbadbob658 Posted January 8, 2014 Author Share Posted January 8, 2014 Did you access the link I provided in post #5?. I did read this but my eyes glazed over. I don't understand scripting, its way over my head. Quote Link to comment Share on other sites More sharing options...
Bogbadbob658 Posted January 8, 2014 Author Share Posted January 8, 2014 Put the new block into a separate drawing, with the 'old' drawing as active, open the design center dialogue and find the new block, right click and select "redefine only". That should work? providing the real names are the same This worked fine (after I renamed the blocks to be the same, I should have read all of your post). Thank you both for your help. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 8, 2014 Share Posted January 8, 2014 I did read this but my eyes glazed over. I don't understand scripting, its way over my head. That post was about lisp not scripting. It contained code to be used in a custom lisp routine. Well it doesn't matter at this point since you did find a solution to your problem which is all that really matters. Good. Quote Link to comment Share on other sites More sharing options...
