Please find the attached screenshot. I need to remove the reference path using lisp.
I used a lisp, in that it will attach the reference path and get inserted all the dwgs from the reference path into one file dwg.
I want a lisp that need to add the reference path and inserted all drawings from the path save as with the folder name then remove the reference path
Try this code -
(defun RemoveDevPath (DevPaths / IAcadPreferencesFiles pathsString DevPaths)
 (vl-load-com)
 (setq    IAcadPreferencesFiles
    (vla-get-files
      (vla-get-preferences (vlax-get-acad-object))
   pathsString
    (vla-get-supportpath IAcadPreferencesFiles)
 (foreach path    DevPaths
   (setq pathsString (vl-string-subst "" path pathsString))
 (vla-put-supportpath IAcadPreferencesFiles pathsString)
How to append the above routine to this lisp
(defun c:iab () (c:insertalldirectory))
(defun c:insertalldirectory (/ DirPath filens)
 (setq DirPath (acet-ui-pickdir))
 (VL-LOAD-COM)
 (SETQ ACADOBJ (VLAX-GET-ACAD-OBJECT))
 (SETQ FILES (VLA-GET-FILES (VLA-GET-PREFERENCES ACADOBJ)))
 (SETQ OLDSUPPORT (VLA-GET-SUPPORTPATH FILES))
 (SETQ NEWPATH (STRCAT OLDSUPPORT ";" DirPath ";"))
 (VLA-PUT-SUPPORTPATH FILES NEWPATH)
 (setq filens (vl-directory-files DirPath "*.dwg"))
 (foreach file filens
   (command "-INSERT" file '(0 0 0) "" "" "")
 (command "Zoom" "e" "")
 (setvar "qaflags" 1)
 (command "explode" "all" "")
 (setvar "qaflags" 0)
 (command "_.saveas" "" DirPath (getvar 'dwgprefix) "dwg" 1))
(command "filedia" "1")
(command "cmddia" "1")
Edited by SLW210
ADD Code Tags!
You need a to enclose the Code (
CODE GOES HERE[/i]
You missed the [/code] at the end.
(vl-load-com)
(princ)[/Code]
Edited by SLW210
Corrected CODE TAGS!
