rk25134 Posted January 6, 2014 Share Posted January 6, 2014 Creation of automate polyline between dimension lines test.dwg Quote Link to comment Share on other sites More sharing options...
rk25134 Posted January 6, 2014 Author Share Posted January 6, 2014 need lisp for automatic creation of polyline Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 6, 2014 Share Posted January 6, 2014 Hi . Are you after drawing a polyline on the left side hand coordinates of the selected dimensions ? Quote Link to comment Share on other sites More sharing options...
ketxu Posted January 6, 2014 Share Posted January 6, 2014 Lack of Information : (defun c:pleasemoredetail() (command "pline" (foreach d (acet-ss-to-list (ssget '((0 . "DIMENSION")))) (command "_non" (acet-dxf 13 (entget d))) ) ) ) And keep having respect 4 forum ^^ http://www.cadtutor.net/forum/showthread.php?63344-Auto-Draw-Polyline/page3 Quote Link to comment Share on other sites More sharing options...
rk25134 Posted January 6, 2014 Author Share Posted January 6, 2014 (edited) I need for right side Edited January 6, 2014 by rk25134 Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 6, 2014 Share Posted January 6, 2014 I need for right side Try this ... (defun c:Test (/ leg ss l) ;; Tharwat 06. jan. 2014 ;; (defun leg (x e) (cdr (assoc x (entget e)))) (if (setq ss (ssget '((0 . "*DIMENSION")))) (progn ((lambda (i / sn a b) (while (setq sn (ssname ss (setq i (1+ i)))) (if (< (car (setq a (leg 13 sn))) (car (setq b (leg 14 sn)))) (setq l (cons b l)) (setq l (cons a l)) ) ) ) -1 ) (if (and l (> (length l) 1) (setq l (vl-sort l '(lambda (p q) (< (cadr p) (cadr q)))))) (entmakex (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length l)) '(70 . 0) ) (mapcar (function (lambda (p) (cons 10 (list (car p) (cadr p))))) l) ) ) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
rk25134 Posted January 6, 2014 Author Share Posted January 6, 2014 thank you its working, please provide for left side also. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 6, 2014 Share Posted January 6, 2014 thank you its working, please change the below code to right side Just change the number 13 to 14 Quote Link to comment Share on other sites More sharing options...
rk25134 Posted January 6, 2014 Author Share Posted January 6, 2014 After changing 13 to 14 I am getting incorrect way as please find the attached screenshot Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 6, 2014 Share Posted January 6, 2014 After changing 13 to 14 I am getting incorrect way as please find the attached screenshot Did you try my routine ? Quote Link to comment Share on other sites More sharing options...
rk25134 Posted January 6, 2014 Author Share Posted January 6, 2014 Yes your routine is working fine. need same for left side also. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 6, 2014 Share Posted January 6, 2014 Yes your routine is working fine. need same for left side also. Not a problem , here is a complete one to work on the two sides besides that one more option for both . Try it and let me know ... (defun c:Test (/ leg _LW ss lt rt k) ;; Tharwat 06. jan. 2014 ;; (defun leg (x e) (cdr (assoc x (entget e)))) (defun _LW (pts) (entmakex (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length pts)) '(70 . 0) ) (mapcar (function (lambda (p) (cons 10 (list (car p) (cadr p))))) pts) ) ) ) (princ "\n Select Dimensions ...") (if (setq ss (ssget '((0 . "*DIMENSION")))) (progn ((lambda (i / sn a b) (while (setq sn (ssname ss (setq i (1+ i)))) (if (< (car (setq a (leg 13 sn))) (car (setq b (leg 14 sn)))) (setq rt (cons b rt) lt (cons a lt) ) (setq rt (cons a rt) lt (cons b lt) ) ) ) ) -1 ) (if (and (> (length lt) 1) (> (length rt) 1)) (if (progn (initget 6 "Left Right Both") (setq k (cond ((getkword (strcat "\n Specify a side [Left/Right/Both] < " (cond (*side*) ((setq *side* "Left")) ) " > :" ) ) ) (*side*) ) ) ) (cond ((eq k "Left") (mapcar '_LW (list (vl-sort lt '(lambda (p q) (< (cadr p) (cadr q))))))) ((eq k "Right") (mapcar '_LW (list (vl-sort rt '(lambda (p q) (< (cadr p) (cadr q))))))) (t (mapcar '_LW (list (vl-sort lt '(lambda (p q) (< (cadr p) (cadr q)))) (vl-sort rt '(lambda (p q) (< (cadr p) (cadr q)))) ) ) ) ) ) (princ "\n <!> You should select two dimensions at least <!> ") ) ) ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
pBe Posted January 6, 2014 Share Posted January 6, 2014 (edited) Like to think the actual drawing would be more complex than the one you posted rk25134 , would you be so kind to post a more realistic drawing sample. Edited January 6, 2014 by pBe Quote Link to comment Share on other sites More sharing options...
rk25134 Posted January 6, 2014 Author Share Posted January 6, 2014 working fine Quote Link to comment Share on other sites More sharing options...
rk25134 Posted January 6, 2014 Author Share Posted January 6, 2014 Any another lisp Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 6, 2014 Share Posted January 6, 2014 working fine Any another lisp Since it is working fine , what is the need to ask for another lisp ? Quote Link to comment Share on other sites More sharing options...
rk25134 Posted January 6, 2014 Author Share Posted January 6, 2014 Please find the attached screenshot. I Used latest routine and enter right option from the lisp Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 6, 2014 Share Posted January 6, 2014 I did work on your first attached drawing . Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 6, 2014 Share Posted January 6, 2014 Let me know if you are careless about this thread anymore . Quote Link to comment Share on other sites More sharing options...
