ali99117 Posted December 27, 2013 Posted December 27, 2013 I am trying to export the following .dwg file to .stl format but the object that has been externally referenced does not make into the .stl file. Could someone tell me what am I doing wrong? here are the files... kinect model.dwg complete turret.dwg Quote
Dana W Posted December 27, 2013 Posted December 27, 2013 I think you probably have to BIND the external reference to the dwg file first. Not sure. I have not had to create a .stl file. I just know that an "attached" external reference is not part of the main dwg file, until the main dwg is opened. Quote
