lucas3 Posted December 22, 2013 Posted December 22, 2013 (edited) Please refer to the following picture Edited December 22, 2013 by lucas3 Quote
marko_ribar Posted December 22, 2013 Posted December 22, 2013 What is the purpose of this?... I normally draw things I don't want to modify, and then just dimension them and that's it... If somethings wrong I repeat the process from start of wrong things that are drawn... I bet I can finish the job faster than with above posted examples for modifications... Quote
DuanJinHui Posted June 4, 2015 Posted June 4, 2015 Powerful ! here is a simple . ;;;author : BDYCAD ;;;2005-03-18 (defun c:tt(/ BLB EP ESPL N-EP N-SP NEW-T SD SD-DXF SEA SEB SP SS1 SS2 SS3) (setq SD (entsel "\nChoose dimension:")) (if SD (PROGN (SETQ SD-DXF (ENTGET (CAR SD))) (WHILE (NOT (wcmatch (CDR (ASSOC 0 SD-DXF)) "*DIM*")) (setq SD (entsel "\nChoose dimension:")) (SETQ SD-DXF (ENTGET (CAR SD)))) (SETQ SP (CDR (ASSOC 13 SD-DXF)) EP (CDR (ASSOC 14 SD-DXF)) ESPL (DISTANCE SP EP) SEA (ANGLE SP EP) SEB (ANGLE EP SP) NEW-T (getdist "\nNew value:")) (while (eq nil NEW-T) (setq NEW-T (getdist "\nNew value:"))) (if NEW-T (progn (setq BLB (* 0.5 (abs (- NEW-T ESPL)))) (if (> ESPL NEW-T ) (setq N-SP (POLAR SP SEA BLB) N-EP (POLAR EP (+ PI SEA) BLB)) (setq N-SP (POLAR SP SEB BLB) N-EP (POLAR EP (+ PI SEB) BLB)) ) (setvar "osmode" (logior (getvar "osmode") 16384)) (setvar "cmdecho" 0) (vl-cmdf "_.undo" "_group") (SETQ SS1 (SSGET "C" (POLAR SP (+ PI (* 0.25 PI)) 0.4)(POLAR SP (* 0.25 PI) 0.4)) SS2 (SSGET "C" (POLAR EP (+ PI (* 0.25 PI)) 0.4)(POLAR EP (* 0.25 PI) 0.4)) ) (IF SS1 (COMMAND "STRETCH" (SSGET "C" (POLAR SP (+ PI (* 0.25 PI)) 0.4)(POLAR SP (* 0.25 PI) 0.4)) ""SP N-SP)) (IF SS3 (COMMAND "STRETCH" (SSGET "C" (POLAR EP (+ PI (* 0.25 PI)) 0.4)(POLAR EP (* 0.25 PI) 0.4)) ""EP N-EP)) (vl-cmdf "_.undo" "_end") (setvar "osmode" (logand (getvar "osmode") 49151)) (PRINC"\nComplete!"))) ) ) (princ) ) Quote
rkent Posted June 4, 2015 Posted June 4, 2015 This is built into AutoCAD with parametric dimensions. Quote
DuanJinHui Posted June 4, 2015 Posted June 4, 2015 This is built into AutoCAD with parametric dimensions. yes, parametric dimensions can do ,but is inconvenient. I'm sure OP' s demo is not use parametric dimensions. Quote
rkent Posted June 4, 2015 Posted June 4, 2015 yes, parametric dimensions can do ,but is inconvenient. I'm sure OP' s demo is not use parametric dimensions. I would be interested in hearing how parametric dimensions are inconvenient. They are as easy to apply as a regular dimension. Quote
tzframpton Posted June 4, 2015 Posted June 4, 2015 Inconvenient = don't know how to use. If you don't know how to use it then that means you've never tried it. They're awesome, especially for Dynamic Blocks. Can be very powerful. Quote
DuanJinHui Posted June 5, 2015 Posted June 5, 2015 I mean "Relative" ,dimensional constraints + geometric constraints. isn't ? Quote
