GP_ Posted December 21, 2013 Posted December 21, 2013 (edited) A graphical approach to approximate a centerline between two polylines. To play p.s. Do not exaggerate with sharp curves. p.p.s. For AutoCAD 2011 or higher centerPline.LSP Edited February 15, 2014 by GP_ 1 Quote
Lee Mac Posted December 21, 2013 Posted December 21, 2013 Interesting method Gian - thanks for sharing! Aside: I never realised vlax-erased-p would accept an ename argument - that's quite convenient Quote
GP_ Posted December 22, 2013 Author Posted December 22, 2013 (edited) Thank you, Lee. ... vlax-erased-p would accept an ename argument In effect: (vlax-erased-p obj) Arguments obj A VLA-object. Edited December 24, 2013 by GP_ Quote
Lee Mac Posted December 22, 2013 Posted December 22, 2013 It would seem that vlax-erased-p is similar to the vlax-curve-* functions in that it will accept either a VLA-Object or ename argument: (contrary to the documentation for these functions): _$ (setq ent (car (entsel))) <Entity name: 7ef16a08> _$ (setq obj (vlax-ename->vla-object ent)) #<VLA-OBJECT IAcadLine 1662331c> _$ (vlax-curve-getendparam ent) 10.0 _$ (vlax-curve-getendparam obj) 10.0 _$ (vlax-erased-p ent) nil _$ (vlax-erased-p obj) nil _$ (entdel ent) <Entity name: 7ef16a08> _$ (vlax-erased-p ent) T _$ (vlax-erased-p obj) T Quote
GP_ Posted October 8, 2014 Author Posted October 8, 2014 You're welcome, suryacad Glad it's of use to someone. Quote
cadplayer Posted October 8, 2014 Posted October 8, 2014 Fantastic done, thanks for your work _GP Quote
GP_ Posted October 9, 2014 Author Posted October 9, 2014 You're welcome cadplayer, thank you for the comment Quote
AIberto Posted October 9, 2014 Posted October 9, 2014 when appload Command: ap APPLOAD centerPline.LSP successfully loaded. Command: ; error: misplaced dot on input Quote
GP_ Posted October 9, 2014 Author Posted October 9, 2014 when appload Command: ap APPLOAD centerPline.LSP successfully loaded. Command: ; error: misplaced dot on input Sorry, I don't know the solution for your problem. Quote
hanhphuc Posted October 10, 2014 Posted October 10, 2014 (edited) Thanks for sharing sir, though i cant try it on 2007 when appload Command: ap APPLOAD centerPline.LSP successfully loaded. Command: ; error: misplaced dot on input i recognize this error happen if dot place before a number. try to separate dot. example: if you see (40 [color="red"][b].[/b][/color]123) at least has space (40 [color="red"][b].[/b][/color] 123) Edited October 10, 2014 by hanhphuc typo: palce -> place Quote
AIberto Posted October 10, 2014 Posted October 10, 2014 Thanks for sharing sir, though i cant try it on 2007 i recognize this error happen if dot place before a number. try to separate dot. example: if you see (40 [color=red][b].[/b][/color]123) at least has space (40 [color=red][b].[/b][/color] 123) My dear friend hanhphuc , Thank you for your idea, I think I found the reason . just I test it with "vlide" , Found the wrong point . Now I open it with notepad++ Quote
GreenDD Posted November 8, 2014 Posted November 8, 2014 Hey guys, can anyone help me to get this work for closed polygons or is there also a LISP code? Quote
marko_ribar Posted November 8, 2014 Posted November 8, 2014 Hey guys, can anyone help me to get this work for closed polygons or is there also a LISP code? Maybe this can help... http://www.cadtutor.net/forum/showthread.php?88968-Endless-Centre-Lines/page2&p=#11 M.R. Quote
GreenDD Posted November 8, 2014 Posted November 8, 2014 Thanks for your anwser M.R.! But it should work more in the way that it create the centerline of one polygon and not with another. So that i get the green centerline out of the with closed polygon in the picture. Quote
mardoq Posted February 2, 2016 Posted February 2, 2016 unfortunately I cant download the routine... there is an error popping out any chance of reuploading? Quote
nasarpki Posted February 14, 2019 Posted February 14, 2019 On 10/9/2014 at 7:14 PM, GP_ said: Sorry, I don't know the solution for your problem. On 12/21/2013 at 9:06 PM, GP_ said: A graphical approach to approximate a centerline between two polylines. To play p.s. Do not exaggerate with sharp curves. p.p.s. For AutoCAD 2011 or higher centerPline.LSP When aploaded getting message "no function definition: VLAX-CURVE-GETENDPARAM" Quote
ronjonp Posted February 14, 2019 Posted February 14, 2019 2 hours ago, nasarpki said: When aploaded getting message "no function definition: VLAX-CURVE-GETENDPARAM" Add (vl-load-com) to the code. Quote
Muthalagan Chidambaram Posted June 2, 2020 Posted June 2, 2020 On 12/21/2013 at 9:06 PM, GP_ said: A graphical approach to approximate a centerline between two polylines. To play p.s. Do not exaggerate with sharp curves. p.p.s. For AutoCAD 2011 or higher centerPline.LSPUnavailable Can i get the CenterPline.LSP file to my mail please. It is not downloadable Quote
Dadgad Posted June 2, 2020 Posted June 2, 2020 (edited) It appears that 615 people have been able to download it, from GP_s original post, which he edited in 2014. 13 of them since yesterday. Edited June 3, 2020 by Dadgad update Quote
