LosGirk Posted December 14, 2013 Share Posted December 14, 2013 Hello, On 14th of Mar. 2012 a member named Big Al posted the dcl code for a program called DD4X3. Does anyone have the lisp code that goes with that dcl file? It's a very nice dialog box with spaces for images, but I can't figure out how to get images to show up. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 14, 2013 Share Posted December 14, 2013 Would it happen to be what is shown in post #28 of the thread you are referring to? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 14, 2013 Share Posted December 14, 2013 Here is the lisp you should have just asked me. used to set up dimension variables ;;; Uses dd4x3.dcl for the dialogue definition. The ;;; slide images are in list ai_pts_lst. (setvar "CMDECHO" 0) (setq ai_pts_lst '("CTONE(DSE1ON)" "CTONE(DSE1OF)" "CTONE(DSE2ON)" "CTONE(DSE2OF)" "CTONE(DTADON)" "CTONE(DTADOF)" "CTONE(DIMTOLP)" "CTONE(DIMTOLM)" "CTONE(DTOLON)" "CTONE(DTOLOF)" "CTONE(DTIHON)" "CTONE(DTIHOF)") ) (setq ai_pts_lst2 '("43sq1" "43sq2" "43sq3" "43sq4" "43sq5" "43sq6""43sq7" "43sq8" "43sq9" "43sq10" "43sq11" "43sq12")) (defun subdlg () (setq dcl_id (load_dialog "ddval")) (if (not (new_dialog "ddval" dcl_id)) (exit)) (action_tile "sizze" "(setq dimval (atof $value))(done_dialog)") (mode_tile "sizze" 3) (start_dialog) ) (defun alan2 () (setq ans $key) (cond ((= ans "43sq1")(setvar "dimse1" 1)(princ "On")) ((= ans "43sq2")(setvar "dimse1" 0)(princ "Off")) ((= ans "43sq3")(setvar "dimse2" 1)(princ "On")) ((= ans "43sq4")(setvar "dimse2" 0)(princ "Off")) ((= ans "43sq5")(setvar "dimtad" 1)(princ "On")) ((= ans "43sq6")(setvar "dimtad" 0)(princ "Off")) ((= ans "43sq7") ;call popup dialog (subdlg) ;(princ dimval) (setvar "dimtp" dimval) ) ((= ans "43sq8") (subdlg) (setvar "dimtm" dimval) ) ((= ans "43sq9")(setvar "dimtol" 1)(princ "On")) ((= ans "43sq10")(setvar "dimtol" 0)(princ "Off")) ((= ans "43sq11")(setvar "dimtih" 1)(princ "On")) ((= ans "43sq12")(setvar "dimtih" 0)(princ "Off")) ) ) ; calculates next slide (defun alan4 () (setq x (+ x 1)) (setq sldname (nth x ai_pts_lst)) ) ; third step ; set up slide libraray (defun ai_ptype_start () (setq x -1) (foreach pts0 ai_pts_lst2 (alan4) (start_image pts0) (slide_image 0 0 (- (dimx_tile pts0) 1) (- (dimy_tile pts0) 1) sldname) (end_image) ) ) ; this is second step (defun ai_ptype_main (/ globals) (ai_ptype_start) ;now check each sq if picked then run alan2 (foreach pd0 ai_pts_lst2 (action_tile pd0 "(alan2)") ) (start_dialog) ) ; this is first step (setq app "dd4x3.dcl") (setq dcl_id (load_dialog app)) (if (not (new_dialog "dd4x3" dcl_id)) (exit)) (ai_ptype_main) (setq *error* old_error old_error nil) (done_dialog) (princ) Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 14, 2013 Share Posted December 14, 2013 BIGAL: The OP probably did not know how to ask you given he just became a member of the forum. Quote Link to comment Share on other sites More sharing options...
LosGirk Posted December 17, 2013 Author Share Posted December 17, 2013 Thank You Big Al- I'm new to this, when I searched your name nothing came up... I'm learning my way around the site better, thanks for being patient with me, and thanks for the code! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 17, 2013 Share Posted December 17, 2013 No worries the routines were done with 2x3 3x3 etc so they could be used with any code. Quote Link to comment Share on other sites More sharing options...
