Sengna Posted December 13, 2013 Posted December 13, 2013 I don't really have problem with using rectangle command but on this drawing, when i drew the rectangle, i specified the first corner and second corner then i didn't get the closed rectagle as i used to have in the past, i still can't figure it out what happened. However i could type C for CLOSE to complete the rectangle but i didn't have to do that in the past. when opened new blank autocad the rectangle command works just fine. appreciate any suggestion. Quote
Sengna Posted December 16, 2013 Author Posted December 16, 2013 Nestly, I used "Purge" commands to get rid of the unused layers and i tried to use the rectangle command and now it worked, when i drew it gave me the closed rectangle, tried to upload the file it said" http://www.cadtutor.net says: "The following errors occurred" Rectangle errow.dwg upload of file failed. Quote
