Where do I go to add/remove things on the toolbar in autocad 2008?
I would like to put the snap to midpoint selection and a few others on the toolbar.
Thanks! :)
you can do that with the CUI but I just shift-right click to get up the OSNAP toolbar
In CUI, drag the command from the command list to the osnap toolbar... you'll need to make your own icon or use the one I attached.
M2P.bmp.txt
Cheers Dave and lpseifert. Got it now :)
Caution. Once you modify the stock OOTB menu, you should keep a current backup. AutoCAD is known for corrupting the CUI file without warning, meaning you will lose your changes.
You might consider leaving the OOTB menus alone and create a custom menu to be partial loaded.
Okay, A custom menu sounds more reliable.
Thanks,
