alijahed Posted December 4, 2013 Posted December 4, 2013 Hi All, Is there any field for the "Number:" box on the attached file so I can use it for my page numbering? Cheers Ali Quote
Gatekeeper101 Posted December 4, 2013 Posted December 4, 2013 it should go the other way, you type the number in there then on the drawing you create the field to the sheetset property. Quote
alijahed Posted December 5, 2013 Author Posted December 5, 2013 You 100% right but I cannot find a field related to that box! Quote
Gatekeeper101 Posted December 5, 2013 Posted December 5, 2013 Here is a youtube video on using fields with a title block Quote
alijahed Posted December 5, 2013 Author Posted December 5, 2013 (edited) Well, This is how I got it, please double check on your side. When you insert field in Attribute it can insert the page number BUT if you use the field in Mtext it cannot pick it up! I am using Field "ctab" in Mtext to print the tab name on my titleblock and it works but as I said it doesn't want to work on Sheet Number! Edited December 5, 2013 by alijahed Quote
