121madhu Posted December 7, 2013 Author Posted December 7, 2013 your code is working perfect check BIGAL code line type ma.lin one file and all line types there Quote
satishrajdev Posted December 7, 2013 Posted December 7, 2013 Change your LIN file according to following code :- *TELECOM,TELECOM TELECOM TELECOM TELECOM TELECOM TELECOM TELECOM A,.1,-.1,["TELECOM",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *SPARE,SPARE line ----SPARE----SPARE----SPARE----SPARE----SPARE----SPARE-- A,.1,-.1,["SPARE",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *STORM_WATER,STORM WATER line ----STORM WATER----STORM WATER----STORM WATER----STORM WATER----STORM WATER----STORM WATER-- A,.1,-.1,["STORM WATER",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *MV_ELECTRICAL,MV ELECTRICAL line ----MV ELECTRICAL----MV ELECTRICAL----MV ELECTRICAL----MV ELECTRICAL----MV ELECTRICAL----MV ELECTRICAL-- A,.1,-.1,["MV ELECTRICAL",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *ELECTRICITY,ELECTRICITY line ----ELECTRICITY----ELECTRICITY----ELECTRICITY----ELECTRICITY----ELECTRICITY----ELECTRICITY-- A,.1,-.1,["ELECTRICITY",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *LANDSCAPING,LANDSCAPING line ----LANDSCAPING----LANDSCAPING----LANDSCAPING----LANDSCAPING----LANDSCAPING----LANDSCAPING-- A,.1,-.1,["LANDSCAPING",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *IRRIGATION,IRRIGATION line ----IRRIGATION----IRRIGATION----IRRIGATION----IRRIGATION----IRRIGATION----IRRIGATION-- A,.1,-.1,["IRRIGATION",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 and here is your modified lisp, but dont forget to put your desktop path.... (DEFUN C:TEST (/ A B C D) (VL-LOAD-COM) (SETVAR "cmdecho" 0) (WHILE (/= (SETQ A (GETSTRING "\nSpecify Name of New Layer :")) "") (SETQ B (CAR (ENTSEL "\nSelect Line to Offset :"))) (INITGET 1) (SETQ C (GETDIST "\nSpecify Offset Distance :")) (SETQ D (GETPOINT "\nSpecify Point on Side to Offset :")) (IF (NOT (TBLSEARCH "LTYPE" A)) (COMMAND "-LINETYPE" "_L" A "C:\\Documents and Settings\\abc\\Desktop\\ma.lin" [color=red][b];<- change this path[/b][/color] "" ) ) (VLA-ADD (VLA-GET-LAYERS (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT)) ) A ) (VLA-OFFSET (VLAX-ENAME->VLA-OBJECT B) (POINTSIDE B D) ) (VLA-PUT-LINETYPE (VLAX-ENAME->VLA-OBJECT (ENTLAST)) A) (VLA-PUT-LAYER (VLAX-ENAME->VLA-OBJECT (ENTLAST)) A) ) (SETVAR "cmdecho" 1) (PRINC) ) Quote
121madhu Posted December 7, 2013 Author Posted December 7, 2013 yes its perfect thank you verry much satish (DEFUN C:TEST (/ A B C D) (VL-LOAD-COM) (SETVAR "cmdecho" 0) (WHILE (/= (SETQ A (GETSTRING "\nSpecify Name of New Layer :")) "") (SETQ B (CAR (ENTSEL "\nSelect Line to Offset :"))) (INITGET 1) (SETQ C (GETDIST "\nSpecify Offset Distance :")) (SETQ D (GETPOINT "\nSpecify Point on Side to Offset :")) (IF (NOT (TBLSEARCH "LTYPE" A)) (COMMAND "-LINETYPE" "_L" A "C:\Users\user\Desktop\\ma.lin" ; "" ) ) (VLA-ADD (VLA-GET-LAYERS (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT)) ) A ) (VLA-OFFSET (VLAX-ENAME->VLA-OBJECT B) (POINTSIDE B D) ) (VLA-PUT-LINETYPE (VLAX-ENAME->VLA-OBJECT (ENTLAST)) A) (VLA-PUT-LAYER (VLAX-ENAME->VLA-OBJECT (ENTLAST)) A) ) (SETVAR "cmdecho" 1) (PRINC) ) (DEFUN POINTSIDE (OBJ PNT / P1 PA P2) (SETQ P1 (VLAX-CURVE-GETCLOSESTPOINTTO OBJ (TRANS PNT 1 0)) PA (VLAX-CURVE-GETPARAMATPOINT OBJ P1) ) (IF (EQUAL '(0.0 0.0 0.0) (VLAX-CURVE-GETSECONDDERIV OBJ PA) 1e-8 ) (SETQ P1 (VLAX-CURVE-GETPOINTATPARAM OBJ (FIX PA)) P2 (VLAX-CURVE-GETPOINTATPARAM OBJ (1+ (FIX PA))) ) (SETQ P2 (MAPCAR '+ P1 (VLAX-CURVE-GETFIRSTDERIV OBJ PA))) ) (IF (MINUSP (SIN (- (ANGLE P1 PNT) (ANGLE P2 PNT)))) (SETQ C (- C)) (SETQ C (+ C)) ) ) Quote
