leech123 Posted November 27, 2013 Share Posted November 27, 2013 Hi i have a drawing boarder that is a block with enter-able text fields for drawing revision etc but for some reason the order in which you would enter the rev's 1,2,3, etc is the wrong way round in the enhanced attribute box. So when i click and start typing i end up with 3,2,1 in the rev boxes. i hope this makes sense and someone can fix this annoying error i have. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 28, 2013 Share Posted November 28, 2013 You can edit the block using block editor BEDIT move the text then ATTSYNC Quote Link to comment Share on other sites More sharing options...
leech123 Posted November 28, 2013 Author Share Posted November 28, 2013 Hi thanks for your reply however this doesn't solve the problem. The position of the text within the block are in the correct place Rev A is in the box for Rev A etc and J down the other end. Its simply the order in which they appear in the enhanced attributes box that wrong. Quote Link to comment Share on other sites More sharing options...
steven-g Posted November 28, 2013 Share Posted November 28, 2013 I think the command Battman will let you change the display order. (move up move down) Quote Link to comment Share on other sites More sharing options...
leech123 Posted November 28, 2013 Author Share Posted November 28, 2013 Excellent that has worked (despite taking a while) a treat for such a daft problem it was very annoying but that has worked for me thanks very much! Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 28, 2013 Share Posted November 28, 2013 I'm going to start with this thread to make a suggestion that many users of AutoCAD should follow. When you learn of a new system variable or command, like BATTMAN or ATTSYNC, add them to a cheat sheet with a brief explanation. The next time you have what appears to be a "problem" and you are struggling to find an answer consult your cheat sheet. This especially holds true for commands/variables we don't use often enough to have it become rote. Quote Link to comment Share on other sites More sharing options...
Tyke Posted November 28, 2013 Share Posted November 28, 2013 if you want to reverse the prompt display order of attributes in block, explode it then redefine it and select all objects using a crossing window. Quote Link to comment Share on other sites More sharing options...
leech123 Posted November 28, 2013 Author Share Posted November 28, 2013 Great idea i don't know why i didn't sign up to this forum a lot sooner. The commands I've remembered but don't use that often are MVSETUP - i use this to rotate viewpoints. & When in an active view port type Z > S > 1/50xp As an example to scale the view port just need to make sure the Display lock is set to no Quote Link to comment Share on other sites More sharing options...
leech123 Posted November 28, 2013 Author Share Posted November 28, 2013 Crossing window - Is that drag left or drag right. If i drag left mine is set to green with a dashed outline. if i Drag right its Blue with a solid outline. Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 28, 2013 Share Posted November 28, 2013 crossing is drag left, window is drag right. You can also override this by typing C or W (I think, its a long time since I did it). And don't forget CP for a crossing polygon. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 28, 2013 Share Posted November 28, 2013 Drag left. Use an color(s) you want. BTW....I have a cheat sheet that spans four pages. There are only a handful of people here that can retain all the information in their heads. I'm not one of them. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 29, 2013 Share Posted November 29, 2013 UCS OB The OB is not in the displayed command line message OB = existing Object Quote Link to comment Share on other sites More sharing options...
