adrath Posted November 27, 2013 Posted November 27, 2013 Ok, I know that I found instructions to do this once through a google search, but have since been unable to find it again. I have two streets which intersect and I need to leave the profiles blank from curb return to curb return at the intersections. I know that I could make two separate profiles for each street, but I've already set it up with just one profile each and I'm lazy and don't want to do it again. I know that there is a way (maybe through the profile properties?) where you can "mask" or "hide" one profile through a certain station range. We have all of our profiles stored in a base file, and then data shortcut them into our cut sheets. I know that I need to apply this "mask" in the base file, and then turn it on in the cut sheet because that is what I did last time. Any help would be very appreciated Quote
Bill_Myron Posted November 27, 2013 Posted November 27, 2013 ConvertLineworkToMaskBlock Just found this undocumented command. Make a closed polyline around what you want to mask, run the command and follow the prompts. Here is a link that has more detailed instructions. Its for alignments, but it works for any AEC Object. http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Alignment-extensions/m-p/1863833 Quote
adrath Posted December 4, 2013 Author Posted December 4, 2013 Thanks, Bill_Myron! This is an awesome command! Quote
