OMEGA-ThundeR Posted November 27, 2013 Share Posted November 27, 2013 Hi, Perhaps a simple question. I'm setting up an installation file in lisp form. I want 'status updates' show in the commandbar/Text window (F2) but i don't want them pushed out by all the commands it's running. 'Back in the days' i used batch files and you could hide lines/commands by adding the @ sign or something like ECHO OFF. Is there a way to hide command from the command bar but still show the text lines like (princ "\n Setting up toolbars...") ? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted November 27, 2013 Share Posted November 27, 2013 (setq echo (getvar 'cmdecho)) (setvar 'cmdecho 0) (command "_.*******") (setvar 'cmdecho echo) 1 Quote Link to comment Share on other sites More sharing options...
sritter09 Posted January 30, 2017 Share Posted January 30, 2017 I know this is an old post but thanks Tharwat. worked perfectly and I will definitely save that one future coding... Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 30, 2017 Share Posted January 30, 2017 I know this is an old post but thanks Tharwat. worked perfectly and I will definitely save that one future coding... Thank you for your feedback. Quote Link to comment Share on other sites More sharing options...
