noobpro70 Posted November 27, 2013 Posted November 27, 2013 May i know how to draw/ insert Cable Tray into my drawing somethings like that >>> ?? I'm using autocad 2012 ! Thank ! Am i need autocad Meps as well ? Quote
MSasu Posted November 27, 2013 Posted November 27, 2013 A (rough) work-around will be to createa multi-line style with 3 elements and use TRACKS linetype for middle one. Although may be difficult to manage it. But, first, you may want to ask a Moderator to fix the thread title... Quote
Dadgad Posted November 27, 2013 Posted November 27, 2013 A work-around will be to createa multi-line style with 3 elements and use TRACKS linetype for middle one. Although may be difficult to manage it. But, first, you may want to ask a Moderator to fix the thread title... Good solution Mircea, I already requested that the thread title be corrected. Quote
noobpro70 Posted November 27, 2013 Author Posted November 27, 2013 autocad mep can be create the cable tray also ? Quote
MSasu Posted November 27, 2013 Posted November 27, 2013 Thanks for backing me up, Dadgad! It may be useful to create a new linetype stating from aforementioned one, but will still be a rough aproach. Quote
ReMark Posted November 27, 2013 Posted November 27, 2013 noob: If you are using AutoCAD MEP 2012 I suggest you change your profile. Have you checked the manufacturer's website? Maybe they have blocks of their cable tray assemblies available for downloading. Cable tray incest? Whoa! Quote
ReMark Posted November 27, 2013 Posted November 27, 2013 I previously mentioned visiting a manufacturer's website. Here is an example. Thomas & Betts Canada has DWG files available to download for free. You select the material, the height, and the type of part needed (left hand side). You are provided with an image of the part and if you look in the upper right hand corner you can click on a link to download a zippied DWG file. http://tnbcabletray.com/drawings/index.asp?Material=AHF&leHeight=&leType=ET&leLength=&Serie=&W1=&W2=&Bottom=&RS=&Angle=&Radius= Quote
Stu_Bas Posted May 29, 2019 Posted May 29, 2019 On 11/27/2013 at 8:48 AM, MSasu said: A (rough) work-around will be to create a multi-line style with 3 elements and use TRACKS linetype for middle one. Although may be difficult to manage it. But, first, you may want to ask a Moderator to fix the thread title... I know this is an old post but I just discovered this and it works great for me as I just wanted to show a general routing layout. I created a different MLSTYLE for each rack size. Thanks, MSasu! Quote
ammobake Posted June 11, 2019 Posted June 11, 2019 Autodesk app store now has lots of add-ons for cable trays. There is also a ton of cable trays and comm stuff on autodesk seek that is available in DWG format. In the old days I would keep cable trays simple and 2D. There were cases in comm room details where I would download the manufacturer block for a specific wall penetration or cable tray but usually for cable trays I would draw a solid light grey hatch between 2 lines 12 inches apart, label it with some text and be done with it. -ChriS Quote
SLW210 Posted June 12, 2019 Posted June 12, 2019 I have an AutoCAD add-on from Cablofil. I haven't messed with cable tray routing in quite some time. Quote
