hi all,
how can I create batch file to open AutoCAD and run script ?
thanks for help
  • Replies 24
  • mostafa badran
    10
  • Tuns
    6
  • ReMark
    2
  • MSasu
    2
Posted Images
You should use the "/b" start-up switch:
"C:\Program Files\AutoCAD 2012\acad.exe" /b "C:\MyScriptFiles\ScriptToRun.SRC"
MSasu
thank you so much I will try it but I prefer batch file.
You said: "how can I create batch file to open AutoCAD and run script?" MSasu's answer was correct. The batch file is used to open AutoCAD. Once AutoCAD is opened the script file is called. The script can process a single drawing or an entire folder of drawings. Is that what you want to do?
You can also use this:
FOR %%V IN ([color="red"]C:\AutoCADscripts\Batchedit\[/color]*.dwg) DO start "T" /w "C:\Program Files\Autodesk\AutoCAD 2012\acad.exe" %%V /b "C:\AutoCADscripts\[color="red"]ScriptName[/color].scr"
You have to have the correct file path in the first portion in red so that it knows what folder to use the script on. Second part in red is the name of the script you want to run. Mwade showed this to me, but it works great. Just paste it into notepad and save it as a .bat file.
Above all I salute you.
It is give me an error like attachment. Please take a look to batch syntax. Please tell me what's wrong.
thanks for your help.
FOR %%V IN (D:\test\dwg\*.dwg) DO start "T" /w "C:\Program  Files\Autodesk\AutoCAD 2012 - English\acad.exe" %%V /b  "D:\test\script\test LTS - 2.scr"
It looks like you are trying to open a "read-only" file and forgot the necessary input in your script.
I agree with ReMark. Your script is wrong somewhere. If you post it we may be able to help you out a bit more.
my script
OPEN
"D:\test\dwg\1.DWG"
ltscale
10
QSAVE
CLOSE
OPEN
"D:\test\dwg\2.DWG"
ltscale
10
QSAVE
CLOSE
OPEN
"D:\test\dwg\3.DWG"
ltscale
10
QSAVE
CLOSE
or this
_.open *1.dwg* (setvar 'ltscale 10.0) _.qsave _.close
Is the file saved in a read only location or do you have it open already?
No.
this file is saved in full control location.
Well if you're using my method of running a batch, which it looks like you are, you need to change your script to this:
ltscale
10
SAVE
QUIT
Make sure you get the two blank spaces that come after the "QUIT" command. I don't know if your script is what is causing the problem, so try this and tell me if it works.
how could this method work with multiple file ?
Because, the method I gave you in post #6 uses the Command Prompt and not AutoCAD. It will run those 4 commands over and over until it has done it on all the files in the specified folder. Besides, if it didn't work, it would be less tedious to make a macro and go through each one individually than it would be to write all those lines over and over again.
OK .
just copy your method in script file without any add as you wrote.
Tuns
I try it and it worked perfectly but I add qsave not save .
Thanks so much.The comments helped a lot.
thank you. ReMark.MSasu
Thanks a lot guys.
