salaxi Posted November 8, 2013 Share Posted November 8, 2013 Hello, well i have a problem on solving an autoCAD homework . i have a pdf with the contours of the altitude of an area and i have to rasterize it as an image in AutoCAD 2006 (i put it on windows paint , then i save it as an img (jpg) ) and then i inserted it in AutoCAD. I have to georeference that image and to fix its scale. How can i do that ? Drawing2.dwg Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted November 8, 2013 Share Posted November 8, 2013 If you have inserted Plain JPEG format image file, it doesn't contain georeference information, its just a plain image so you cannot georeference it. You have to adjust it to by rotating or scaling.... Best method to adjust such images is (command - "ADERSHEET" ) but i think it is only available in Autocad Map 3D. Not in plain autocad. Quote Link to comment Share on other sites More sharing options...
