Hello, well i have a problem on solving an autoCAD homework . i have a pdf with the contours of the altitude of an area and i have to rasterize it as an image in AutoCAD 2006 (i put it on windows paint , then i save it as an img (jpg) ) and then i inserted it in AutoCAD. I have to georeference that image and to fix its scale. How can i do that ?
Drawing2.dwgFetching info...
If you have inserted Plain JPEG format image file, it doesn't contain georeference information, its just a plain image so you cannot georeference it.
You have to adjust it to by rotating or scaling....
Best method to adjust such images is (command - "ADERSHEET" ) but i think it is only available in Autocad Map 3D. Not in plain autocad.
