danielk Posted November 2, 2013 Share Posted November 2, 2013 PERSPECTIVE set to 1 LIGHTINGUNITS set to 2 if im not assigning materials it looks fine , the problem is with materials it looks like this . another question LIGHTINGUNITS connected some how to the sun ?? tried couple of metrials same results in all of them , at the picture you can see all the pipes are rendered with materials and the accessories are without Thanks in Advance ,and sorry for my english;) Quote Link to comment Share on other sites More sharing options...
sigaukedenn Posted November 3, 2013 Share Posted November 3, 2013 switch off the lighting settings and return to default lighting, save settings and close the dwg. when it responds to the new settings, try again putting the lights all over again, but make sure you bring in shadows and forget daylight settings. if it doesnt work then i am bumped, because your rendering picture is downright weird, i would have said your lighting is too close but the contrast matter is out of this world. Quote Link to comment Share on other sites More sharing options...
danielk Posted November 4, 2013 Author Share Posted November 4, 2013 worked! Thanks so how do i work with sunlight? Quote Link to comment Share on other sites More sharing options...
Titi95 Posted November 5, 2013 Share Posted November 5, 2013 Hello this is not a tutorial but a small video I made that explains (quickly) tweaks the sun and light in autocad. Quote Link to comment Share on other sites More sharing options...
danielk Posted November 5, 2013 Author Share Posted November 5, 2013 Hello this is not a tutorial but a small video I made that explains (quickly) tweaks the sun and light in autocad. Thanks i will take a look! Quote Link to comment Share on other sites More sharing options...
