I would like to bend something flat using the flex tool. With the help of tutorials, I have already been able to bend one of the angles(angle a at 90°) but then I cant bend the others because the axis and planes shift afterwords....Does anyone have any advice?
Here is pdf that shows what I want to achieve....
question.pdfFetching info...
The flex tool? Never heard of a flex tool in AutoCAD.
Can you post a screen capture of the interface?
Are you using Inventor and posted in the wrong forum? Or, are you using an add-on to AutoCAD? If you are using an add-on what is the program's name?
Flex Tool is in Solidworks AFAIK.
Thread moved to Solidworks, maybe the OP will return and clarify.
Why are you using the Flex command? Have you tried the sheet metal tools? You will achieve more accurate results with sheet metal tools.
