Hi!
My name is Pavel.
My issue is the following:
I need to cover a body with a sheet.
The problem is that the sheet is covering body too tightly.
(the image is attached)
What parameters should I change in cloth modificator,
so it will look real
Thank you in advance,
Pavel.
  • 2 years later...
Not an easy answer. A lot of the cloth simulations are trial and error. You could look up tutorials on using the cloth modifier to get some ideas...that would be a start.
I doubt you'll be getting a response from a thread that dates back two years and a person who posted once then never again.
