Im trying to use the array command in lt2014, using the rectangular I can nearly get there apart from where is the old "row offset" and "column offset" buttons gone? If I don't know the offset as its on say louvre blade block by others I just want to snap to 2 points to set the distance. How is this done with the new array command?
Try ARRAYCLASSIC if the "old" array dialog box suites your needs better.
Will do but seams strange not to include in latest commands
Is there anyway to select say row offset to 2 points in the new array command ?
Array - rectangle - spacing, this should allow you to choose column and row spacing either by typing the distances or picking points
Thanks for that, works spot on - I was trying that before but not realizing that it asked for col spacing first before rows (which is what I was trying to array). Lesson 1 - read the command line. Once again thanks.
