Hello! I'm working in a dynamic block and I think that I've had to mark or unmark some option in the program because since yesterday I can't use as an initial point of any parameter some central points. I mean, when I try to specify the initial point of any parameter (e.g.: rotation) where the four lines converge, the program tells me that the " 2d object is not valid". I hope I've explained myself right... :oops:
Can you help me to restore anything that I might have changed? Thank you very much!
Warp.dwg
WOW I'm impressed, nice block, the problem is it is 3D and the block editor isn't too happy with that, the four lines you mention where not on the working plane so I moved them down to Z=0, if you need them elevated then place your actions first and then move the lines back to where you need them.
EDIT --- maybe OSNAPZ will help (I can't test it, it's not available in LT) sorry it's the second DWG I couldn't figure out how to delete the first
Warp.dwg
Warp.dwg
Edited by steven-g
I thought there was no such thing as a 3D dynamic block?
The content is and can be 3D, it's just the actions that are limited to 2D
Thanks a lot!!!! Now it's working perfectly... :thumbsup: I still have so much to learn...
You are welcome, we are all learning, I didn't realise before today that 3D blocks could cause an issue this way, it's good to know.
