Guys,
I got this code, to do a multiple offset, it works good, but I need to do one complementation in that, the direction of final objects, the code doesn't allow you choose it, every time the code draw the offset line above of objects, It's possible fix it? Indicating the direction of end offset lines...
Thanks in advance...
(defun c:mo (/ plines ; selection set of polylines
      ext ; extrnal point
      dist ; distance to offset
      poly ; a polyline from plines
      plist ; the list of poly
      del ; polyline to delete
      int ; internal point
      i
      layer)
 (command "undo" "begin")
 (princ "select polylines")
 (setq plines (ssget)
i      0
ext    (getvar "limmax")
dist   (getdist "distance = ")
 (repeat (sslength plines)
   (setq poly (ssname plines i))
   (setq plist (entget poly))
   (command "offset" dist poly ext "")
   ;(setq del (entlast)
   ;int (polar
   ;(cdr (assoc 10 (entget del)))
   ;(angle
   ;(cdr (assoc 10 plist)))
   ;(* 2 (distance (cdr (assoc 10 plist))
   ;(cdr (assoc 10 (entget del)))))))
   ;(command "offset" dist poly int "")
   ;(entdel del)
   (setq i (1+ i))
 (command "undo" "end")
 (if (= "Y"
 (strcase (getstring "\ndelete initial polylines? (Y/N) = "))
   (command "erase" plines "")
Untested, but should fix the issue. I changed "ext" (added getpoint) and "dist" (added \n)
      ext ; extrnal point
      i
      layer)
i      0
ext    (getpoint "\nSelect the offset direction")
dist   (getdist "\ndistance = ")
   ;int (polar
   ;(angle
   ;(entdel del)
   (setq i (1+ i))
 (if (= "Y"
Tested!... Thanks CheSyn!... Works well!!!...
  • 3 months later...
HI to all!
Is there a way to add to the above code the ability to change the layer also of the offset objects??
Thanks in advance!
  • 4 weeks later...
To change the layer of newly created polylines (adjust part in blue to suit your case):
   [color=magenta](command "_CHPROP" (entlast) "" "_LA" "[color=blue]NameOfTargetLayer[/color]" "")[/color]
Wow thank you so much! Really appreciate your help! Works exactly as needed!
