Hello guys,
I again, needing a help...
Some one knows how do a link with lines as the picture bellow? I have on a drawing lines that need to be closed to make one area, but, to do it it's necessary to get some lines and do a contour line, linking the points...
Thanks...
Hello guys,
Thanks...
What are those circles? are they part of the "drawing lines" or just a guide to link the contours? as always you need to provide a drawing sample.
The link troggarf posted looks promising.
The circles are only to show what points I need to link!...
My version :)
(defun c:Test (/ ss in en st nd up dn u d)
 ;;     Tharwat 18.Oct.2013    ;;
 (if (setq ss (ssget '((0 . "LINE"))))
     (repeat (setq in (sslength ss))
       (setq en (entget (ssname ss (setq in (1- in))))
             st (cdr (assoc 10 en))
             nd (cdr (assoc 11 en))
       (if (> (cadr st) (cadr nd))
         (setq up (cons st up)
               dn (cons nd dn)
         (setq dn (cons st dn)
               up (cons nd up)
     (setq u (vl-sort up '(lambda (a b) (< (car a) (car b))))
           d (vl-sort dn '(lambda (j k) (< (car j) (car k))))
     (while (> (length u) 1)
       (entmakex
         (list '(0 . "LINE") (cons 10 (car u)) (cons 11 (cadr u)))
       (setq u (cdr u))
     (while (> (length d) 1)
       (entmakex
         (list '(0 . "LINE") (cons 10 (car d)) (cons 11 (cadr d)))
       (setq d (cdr d))
And this one draw LWpolylines .
(defun c:Test (/ _LW ss in en st nd up dn u d)
 (defun _LW (lst)
   (entmakex
     (append (list '(0 . "LWPOLYLINE")
                   '(100 . "AcDbEntity")
                   '(100 . "AcDbPolyline")
                   (cons 90 (length lst))
                   '(70 . 0)
             (mapcar (function (lambda (p) (cons 10 p))) lst)
               dn (cons nd dn)
               up (cons nd up)
     (if (> (length u) 1)
       (_LW u)
     (if (> (length d) 1)
       (_LW d)
:thumbsup: Tharwat, This code LWpline is that I need!... Thank you a lot!!!...
You're welcome anytime . :)
Arent there two sets of lines to select , the white lines on top and the red lines at the bottom?
Yes pBe, there are two lines blue and red, I need to execute the code twice, but it's working as good as I need!...
Ok then, save us time to write a code for that condition :)
Cheers CafeJr.
Cheers CafeJr.
I'm grateful, about your help!!!...
:thumbsup:
