eugenio aburto Posted October 18, 2013 Posted October 18, 2013 I am working in meter system, before I did in Imperial, no problem with hatches, but now, the patterns doesn't show only works with solid. Try AR-CONC and say at "Preview": "Unable to hatch the boundary, which is a simple rectangle shown right at "Add: Select objects". What is wrong? Quote
Tiger Posted October 18, 2013 Posted October 18, 2013 My first guess is that the scale is wrong - try changing the scale on your pattern, change it radically (100 or 1000 perhaps?) and see if you can find a scale that works. Quote
Murph_map Posted October 18, 2013 Posted October 18, 2013 Also when using metric system as your units make sure your starting dwt is one of the metric dwts. (xxxxxISO.DWT) Then all linetypes, hatch, etc are of the proper scales. Quote
