Block attribute position
Im creating a block that has attributes created in a certain position, why is it when I move the attributes in the block editor they dont move relative to the bock in the drawing when I save and close block editior
If you select the block before you go into block editor, it should move them. If you just go into block editor without selecting the block it seems to have issues with moving them around. I can't explain why because I have that same issue.
Just realised it,s not dynamic any future blocks placed will display the attributes in their new position
Even dynamic blocks will have your problem.
No what I'm saying is blocks already placed will not be updated, newly placed ones hold the new properties
Unless you select the block before going into block editor.
Selecting it seems to only work sometimes. That's odd.
You need to run ATTSYNC to update the attribute changes.
attsync is not a command 2008lt recognises
ATTSYNC was not added to LT until 2010 I believe.
You will just have to replace the old one with the new one then.
Sorry, didn't pay attention to what year you were using.
not easy without ATTSYNC, unless you have BATTMAN? I guess that would have appeared about the same time though.
