filsoof13 Posted October 17, 2013 Share Posted October 17, 2013 Hi. I have a complicated 3d mesh and i want to use some edges in another software. The software accepts lines and i want to convert mesh to simple lines. I can make 3d polyline from the mesh but i can't convert it to line. Does anyone know how we can convert mesh to line or 3d face to line or 3d polyline to line? Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 17, 2013 Share Posted October 17, 2013 What if you were to explode the 3Dpolyline? Quote Link to comment Share on other sites More sharing options...
filsoof13 Posted October 17, 2013 Author Share Posted October 17, 2013 If i explode 1 3dpolyline it creates 2 lines and my model will have 1 extra point. I need a method which creates 1 line from 1 3dpolyline. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 17, 2013 Share Posted October 17, 2013 Then maybe what you need is a lisp program that will draw over your exploded line, consisting of 3 points, with a line containing only 2 points. Quote Link to comment Share on other sites More sharing options...
filsoof13 Posted October 17, 2013 Author Share Posted October 17, 2013 I'm not familiar with programming. can you please help me to find a way to solve the problem? Quote Link to comment Share on other sites More sharing options...
Tyke Posted October 17, 2013 Share Posted October 17, 2013 If a 3D polyline has 4 segments (ie 5 vertices) when it is exploded you would have 4 separate lines each with 2 endpoints (ie 8 points). If you explode your mesh you will get 3D faces. If you explode all your 3D faces vou will end up with triangles made up of separate lines, but with lots of duplicates because two adjacent faces will each producw a line on their common edge. You could use OVERKILL to get rid of the duplicates. Quote Link to comment Share on other sites More sharing options...
filsoof13 Posted October 17, 2013 Author Share Posted October 17, 2013 I use AutoCad 2012 and it does not explode 3d faces. Should i use another command instead of "explode" to explode them? Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 17, 2013 Share Posted October 17, 2013 Convert the 3DFace to a Region then explode the region. Quote Link to comment Share on other sites More sharing options...
Tyke Posted October 17, 2013 Share Posted October 17, 2013 I use AutoCad 2012 and it does not explode 3d faces. Should i use another command instead of "explode" to explode them? I've done it in the past in 2012. Select the normal Explode tool or issue the command and select your mesh. Quote Link to comment Share on other sites More sharing options...
filsoof13 Posted October 17, 2013 Author Share Posted October 17, 2013 It does not convert 3dface to region! ( I use "region" command) Quote Link to comment Share on other sites More sharing options...
filsoof13 Posted October 17, 2013 Author Share Posted October 17, 2013 I've done it in the past in 2012. Select the normal Explode tool or issue the command and select your mesh. I exploded mesh to 3dface but 3dfases can't be exploded! Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 17, 2013 Share Posted October 17, 2013 Calm down. Did you even bother to read my post regarding how to explode a 3DFace? Quote Link to comment Share on other sites More sharing options...
filsoof13 Posted October 17, 2013 Author Share Posted October 17, 2013 How can I convert a 3dface to a region? "Region" command does not work! Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 17, 2013 Share Posted October 17, 2013 In my quick test the Region command did work on a 3DFace. Here is another option. Try the FLATTEN command. Forum member rkmcswain suggests this: WMFOUT and WMFIN also will work. Convert a 3DFace to a 3d or 2D polyline using sample code found here...http://adndevblog.typepad.com/autocad/2013/01/convert-3dface-to-polyline.html Quote Link to comment Share on other sites More sharing options...
filsoof13 Posted October 17, 2013 Author Share Posted October 17, 2013 It says: Command: REGIOn Select objects: 1 found Select objects: 1 closed, degenerate or unsupported object rejected. 0 loops extracted. 0 Regions created. I'm not an expert and I don't know what it means. About the 3d face I have chosen above it says: 3D FACE Layer: "2D property 1" Space: Model space Handle = d9f4 first point, X= -1.6021 Y= 1.6040 Z= 0.7000 second point, X= -1.6021 Y= 1.6870 Z= 0.6850 third point, X= -1.5631 Y= 1.6890 Z= 0.6810 fourth point, X= -1.5641 Y= 1.6060 Z= 0.6960 I've seen these commands before. I think these 3 commands will produce lines with z=0 elevation. Am I wrong? I need lines in their correct position. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 17, 2013 Share Posted October 17, 2013 I need lines in their correct position. Then I guess FLATTEN won't be of any use. Did you try rkmcswain's suggestion? Maybe the task could be accomplished in another program. Perhaps Inventor or Inventor Fusion? Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 17, 2013 Share Posted October 17, 2013 For anyone interested I found a lisp routine that purports to convert 3DFaces to lines over at the CADforum. It is called 3DF2L.lsp and can be found here...http://www.cadforum.cz/cadforum_en/download.asp?cat=33 Quote Link to comment Share on other sites More sharing options...
David Bethel Posted October 18, 2013 Share Posted October 18, 2013 This will convert 3DFACEs to 3DPOLYLINES ; [b][color=BLACK]([/color][/b]defun c:fa23dpl [b][color=FUCHSIA]([/color][/b]/ ss i en ed[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"3DFACE"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq i 0[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entmake [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"POLYLINE"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 66 1[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]list 10 0 0 0[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]cons 70 9[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]foreach p '[b][color=GREEN]([/color][/b]10 11 12 13[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]entmake [b][color=BLUE]([/color][/b]list [b][color=RED]([/color][/b]cons 0 [color=#2f4f4f]"VERTEX"[/color][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]assoc 8 ed[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 10 [b][color=PURPLE]([/color][/b]cdr [b][color=TEAL]([/color][/b]assoc p ed[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 70 32[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entmake [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"SEQEND"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]assoc 8 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entdel en[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq i [b][color=GREEN]([/color][/b]1+ i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]redraw[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote Link to comment Share on other sites More sharing options...
filsoof13 Posted October 19, 2013 Author Share Posted October 19, 2013 For anyone interested I found a lisp routine that purports to convert 3DFaces to lines over at the CADforum. It is called 3DF2L.lsp and can be found here...http://www.cadforum.cz/cadforum_en/download.asp?cat=33 Hi. Thank you ReMark! I was busy yesterday and I could find time to check forum now and I am surprised! Thank you very much! It works and helps me so much. I can say just thank you again. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 19, 2013 Share Posted October 19, 2013 I'm glad to hear that the lisp routine I referenced in my previous post worked for you. Thanks for updating us. Quote Link to comment Share on other sites More sharing options...
