Aligned Dimension
I have a series of straight walls creating a section of anarc and joining each other at different angles. I want to place dimension alignedto a wall at its end points. Basically I want to select the end points of thewall and have the dimension aligned between these 2 points. How do I select the end points of a wall to place a dimension?
You can tab through available object snaps or type SE to get just the endpoint.
