jbgraphic Posted October 4, 2013 Posted October 4, 2013 Wondering what things may cause my mouse to be not smooth? I have tried a couple different mouses with same results so figure it is a setting or something. Using autocad 2013. At school it runs nice and smooth at home not so much. using win 7 8g ram 2500K i5 v4800 card Quote
Dadgad Posted October 4, 2013 Posted October 4, 2013 Try turning off your SNAP MODE (not to be confused with your OSNAPS), find the icon in the lower left corner of your screen, or toggle it with button F9. Quote
jbgraphic Posted October 4, 2013 Author Posted October 4, 2013 I don't have that on. Can dynamic input cause issues? Who uses dynamic input? Quote
Dadgad Posted October 4, 2013 Posted October 4, 2013 You can certainly toggle Dynamic Input on and off with F12, or at the icon on the status bar. Can you take and post a screenshot of your status bar at the bottom of your screen, which will show the status of all your toggles? Quote
Dadgad Posted October 4, 2013 Posted October 4, 2013 Do you have HARDWARE ACCELERATION enabled, or is it turned off? You can find the Icon in the lower right corner of your screen. Quote
SLW210 Posted October 4, 2013 Posted October 4, 2013 Do you have the latest graphics card drivers from Autodesk? AMD v4800 Quote
jbgraphic Posted October 17, 2013 Author Posted October 17, 2013 Here is a screen shot. I do have the latest video card driver. Thanks for looking and helping me out here if possible. Quote
SLW210 Posted October 17, 2013 Posted October 17, 2013 Does turning Hardware Acceleration on or off make a difference? Type 3DCONFIG and check or uncheck, you can also select the VIEW TUNE LOG and past the info here (in code tags). Here are some tips from Autodesk site Cursor is slow or jerky Quote
