I have just started using Autocad 2010 (i know i know, its not the latest :))... but anyways.
I am facing this unique problem where i have a 3d solid object in the drawing, and when the first point in a pline command falls within the boundary of the 3d solid, autocad automatically assigns some of the properties of the 3dsolid to the new polyline i draw.
so for example, in the attached file, even if i am selecting pline command and starting a command within the rectangle (start point shown as a circle), it automatically changes the z coordinates so that the resulting pline is angled to the xy plane.
I a not sure how this happens, and how I can turn it off. Any help will be much appreciated.
ask.dwgFetching info...
Have you tried disabling the Dynamic UCS?
