inventor dimensions
is it possible to draw dimensions in 3d model view like this
I want dimensions in 3d model mode.not in drawing mode. Using inventor2013.Also is it possible to do render with dimensions? also show dimensions is not what i want.i want specific dimensions to be shown
Is that Autodesk Inventor
or
is that Inventor Fusion?
There used to be an add-in here http://labs.autodesk.com that does what you describe, but I don't think it is available now.
drawing is from solid edge.and i want to do this in inventor 2013
I doubt this is the answer you are looking for because you are not "drawing" the dimensions... but you could show sketch dimensions.
you mean to show dimensions from draft on 3d model?
Ye I use this method, you have to turn the visibility of the sketch on first, this will also turn on the dimensions. From memory dimension visibility turned up in IV2013 so you should be ok.
