rickmalabares Posted October 2, 2013 Posted October 2, 2013 First of all sorry for my bad english. I wonder how do I change the default value of the angle that is between in the command UCS "specify rotation angle about X axis :" from 180.00 to 90.00 Thanks Quote
121madhu Posted October 2, 2013 Posted October 2, 2013 Change dwg. UCS First “UCSFOLLOW” set to “0” Then “UCS” enter “e” enter select what u want angle direction line And another change only cursor hair “snapang” enter value ok. Quote
rickmalabares Posted October 2, 2013 Author Posted October 2, 2013 121madhu said: Change dwg. UCS First “UCSFOLLOW” set to “0” Then “UCS” enter “e” enter select what u want angle direction line And another change only cursor hair “snapang” enter value ok. Thanks for the help but did not work the way I wanted. I'm working on the SW isometric and the reason I want to change the default value of 180.00 to 90.00 is for all the times I typed the command UCS then enter X I do not need to enter the angle of 90.00. The angle of 90.00 would be the default angle Quote
ReMark Posted October 2, 2013 Posted October 2, 2013 You're looking for a system variable. Command: UCSAXISANG Enter new value for UCSAXISANG :90 Then press the Enter key. Done. Quote
ReMark Posted October 2, 2013 Posted October 2, 2013 Usually Dadgad handles the System Variables explanations but I think he is on holiday. Quote
rickmalabares Posted October 2, 2013 Author Posted October 2, 2013 ReMark said: You're looking for a system variable. Command: UCSAXISANG Enter new value for UCSAXISANG :90 Then press the Enter key. Done. Thanks ReMark That's the command I was looking for. Quote
