Dynamic blocks and angle offset
I am fairly new to Auto Cad and I am currently trying to figure out how to use dynamic blocks. I can not seem to figure out how to use the angle offset and stretch and then preform a successful scale. I am working from a tutorial in dynamic blocks in auto cad part 3 trying to create the door. If anyone has worked with this and can help please let me know thank you.
Which part is giving you trouble, attached is an example of the door block, read through the description you have and then open the block in block editor and see if it makes sense, clicking on an action will show you the properties.
DoorBlock.dwg
I see where I messed up thank you very much :)
