Hi everyone!!!
I know my question should be a easy question for a mid level civil 3d user, but not for me.
I need to create a worst defined contour from a surface created via well shaped contours, why I need this, because a need to export a surface without to much detail to a fem program (plaxis).
So the question is; How to create new contours from a already created surface_
Hope you can help me.
Hi everyone!!!
What do you mean by "worst defined contour"?
Hope I can explain myself.
The contours I have, have a lot of snap points, so when there is a curve it generates a lot of triangles which can define very well a curve section, but this triangles are so irregular in ther lengths (they are not equilateral), but because the application which I am working on, a prefer few triangles but with regular shapes (equilateral lengths) I dont care if they dont reproduce so exactly the curves... this is because in fem analysis thats a good practice.
So i was thinking that I could create a surface from the real-originals contours and then from that surface create new contours, but with less points from which triangles will be created.... I was thinking it should be an option which says something like ¨preferred aproximation, or number of snaps¨don´t know, hope you can help me....
Or/and how to export surfaces to a *.3ds format.
Gracias por su tiempo dedicado.
Are you using civil3D or Vanilla AutoCAD and what version? If using C3D look at the Smoothing functions and/or using Civil Views in 3ds Max.
Señor,
instead of simplifing an existing surface, try to weed the original contours (command _MAPCLEAN => "Simplify objects") then recreate the surface.
