Custom Door tags in Revit 2009
Basically what I'm trying to do is create a door tag or formula which will allow me to match my room numbers with the door numbers. (ie my room number is 3A101, the door that I create to that room is labeled door 3A101 by associating it self with that room. Or when I add a door tag the tag number reflects on the room name)
Thoughts anyone?
the only way i can think is to make a shared parameter for each tag (room and door) and add them in the tag family for each.
i will give it a quick go a lunch or when i get 5 mins
  • 2 months later...
How will you distinguish what room the door is associated with?
For example, if a door leads from an office to reception, does that door belong to the office or reception?
Did you try Avatechs Revit Utility? They have a door numbering utility that looks promising.
